chris west Posted November 28, 2013 Share Posted November 28, 2013 Back again guys .. My front pipe to mid box is kicking out fumes back towards cylinder .... What's the best fix .. Tarried exhaust sealant and it just keeps cracking and look awful .. Cheers Quote Link to comment Share on other sites More sharing options...
Andy Posted November 28, 2013 Share Posted November 28, 2013 Another topic moved. Please post in the correct forum. Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2013 Share Posted November 28, 2013 Hey Chris, have you ever considered the exhaust could be plugged up? Quote Link to comment Share on other sites More sharing options...
chris west Posted November 28, 2013 Author Share Posted November 28, 2013 I've just stripped and repacked silencer .. So it jet be mid box then ... Itspreety mingling .. Anyone know part number or good clean method .. Thanks Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2013 Share Posted November 28, 2013 It is possible to over pack a silencer, you might try riding without the silencer. Quote Link to comment Share on other sites More sharing options...
chris west Posted November 28, 2013 Author Share Posted November 28, 2013 It leaked the same before I repacked .. The front pile seems ok but Middle is very oily Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2013 Share Posted November 28, 2013 It is not a matter of it leaking, it has to be able to breathe. What happened to your post about jet size? Quote Link to comment Share on other sites More sharing options...
chris west Posted November 28, 2013 Author Share Posted November 28, 2013 I am new to this and posted about six probs with this bike I've bought .. U see it was in storage for 5 years and a right mess when I got it .. I'm trying to set the carb up now .. It idled great for about 30 Seconds then revs like crazy I have to shut it off at switch .. I've just stripped carb down today cleaned all jet but changed needle clip to its lowest notch .. Is this the problem .. Thanks for help Quote Link to comment Share on other sites More sharing options...
smalley250 Posted November 28, 2013 Share Posted November 28, 2013 caustic soda is what i used as a kid on me TY175 middle box. Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2013 Share Posted November 28, 2013 Chris, you should reply to Jon on the Boyesen reed post on what jets you found. Also verify what carb you have. It should be the VHST (flat slide), but the jetting you have is off for any that I remember. Quote Link to comment Share on other sites More sharing options...
jse Posted November 28, 2013 Share Posted November 28, 2013 Chris, you should reply to Jon on the Boyesen reed post on what jets you found. Also verify what carb you have. It should be the VHST (flat slide), but the jetting you have is off for any that I remember. Lineway, Chris has a 2002 so the carb is undoubtedly a PHBL26. The VHST was only used on the 2003 Pro and is actually a pretty good carb (if you bought a new one) but I think they had a manufacturing defect/design in 03' that made them hard to tune. Hopefully he will post the jetting and we'll see if that's part of the problem. Cheers. Jon Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 28, 2013 Share Posted November 28, 2013 He said earlier a 140 and a 30 pilot. I would have swore one post he said it was a 2003. Quote Link to comment Share on other sites More sharing options...
jse Posted November 29, 2013 Share Posted November 29, 2013 He said earlier a 140 and a 30 pilot. I would have swore one post he said it was a 2003. Jetting seems to be off: main should be probably a #118, pilot a #36 or #38 and try clip second groove from top. I don't remember any PHBL's with lower than a #35 pilot stock. May have been trying to compensate for the over rich main. I run a 116/38 combo in my 02' Pro but it has some mods. Jon Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 29, 2013 Share Posted November 29, 2013 He had two posts that are gone. Yeah, I know what either carbs are supposed to be, it sounded like mikuni jetting. He has something strange going on. Quote Link to comment Share on other sites More sharing options...
jse Posted November 29, 2013 Share Posted November 29, 2013 He had two posts that are gone. Yeah, I know what either carbs are supposed to be, it sounded like mikuni jetting. He has something strange going on. Seems quite a bit off, the VHST takes an even smaller main. Like I say, never assume a used bike you've bought has proper jetting (or has had any maintenance).... Jon Quote Link to comment Share on other sites More sharing options...
