2007 Sherco Manual?
Is there anywhere online with a manual for a 2007 250 sherco? I need to change fork seals and wouldn't mind a look at a manual before I do it. Thanks
The last really good Sherco manual I saw was from the pre-cartridge fork days.
It's unfortunate that there is so little good literature.
If you can't find anything, I could walk you through it.
If you've had forks apart before, it'll seem familiar.
The different thing about cartridge forks is emptying and refilling the cartridge.
There are specs available for oil volume and level.
I found that if you empty and rinse the forks, the volume numbers were spot on for getting the right level.
Try this....Google "changing Sherco fork seals" lots of info comes up.
Good luck Taff
Might try reading the recent thread on fork seals and fixing leaks, just FYI.
