badgert4 Posted February 26, 2014 Share Posted February 26, 2014 Hi there, I've just got hold of this beauty and I'm gonna restore it and compete in twin shock trials . Does anyone out there know what year it is roughly ? Frame no on steering head is JB-15100484 if that helps . I've just taken the top end off and I now know the motor is a 5 speed 350 . Any info greatly appreciated . Thanks Lee Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted February 26, 2014 Share Posted February 26, 2014 The m151 is a 75-76 the motor should be the same number as the frame. And a m151 is a 326cc motor. Nice find and have fun with it. Quote Link to comment Share on other sites More sharing options...
legs Posted February 26, 2014 Share Posted February 26, 2014 Hello, Bultaco Sherpa Model 151 was made between October 1974 and February 1975 Dave Renham In Motion Bultaco UK 1 Quote Link to comment Share on other sites More sharing options...
badgert4 Posted February 26, 2014 Author Share Posted February 26, 2014 Ok great , thanks for your helps guys . Lee Quote Link to comment Share on other sites More sharing options...
badgert4 Posted March 5, 2014 Author Share Posted March 5, 2014 Dave, One thing thats strange is my frame rails dont go under the motor like other 74/75 models I've seen photos of . My down tube stops at the front where the bash plate bolts on . Is that correct ? Cheers Lee Quote Link to comment Share on other sites More sharing options...
twinnshock Posted March 5, 2014 Share Posted March 5, 2014 it is difficult to see from the photographs but it looks like your bike is fitted with an aluminium bash plate. The rest of the frame looks to me standard. If I am correct your frame hs been modified. Quite a common mod in the day. Sammy Miller supplied a frame with this feature from early 70's but not done by Bultaco as standard until the 198A/199A in l978. Stuart Quote Link to comment Share on other sites More sharing options...
badgert4 Posted March 5, 2014 Author Share Posted March 5, 2014 Stuart, Ah I see . Perhaps these pics will shed some light on it ... Thanks Lee 1 Quote Link to comment Share on other sites More sharing options...
sparks2 Posted March 5, 2014 Share Posted March 5, 2014 Yes, I agree with TwinShock, your frame has been modified and it has been done quite well. Quote Link to comment Share on other sites More sharing options...
twinnshock Posted March 5, 2014 Share Posted March 5, 2014 (edited) Lee, Looking at the new pictures just confirms my first guess. Standard frame modified. As Sparks2 has said, looks well done. That looks to be the original cross tube at the back with a plate to support the Alloy plate welded in quite neat and better than my own converted bike. Quite a lot of riders did this. Interesting rear hub, two part design. I suspect correct part but only fitted for a short production period. Tank is also interesting. Correct fit for non UK bikes but I would have expected to see Alloy Homerlite tank fitted in UK. If this was my bike I would be keen to keep this much as it is but I would loose the plastic mudguards. Does look like you have a small bit of polishing to do! But do not be put off I think my M10 was worse when I got it. Stuart Edited March 5, 2014 by twinnshock Quote Link to comment Share on other sites More sharing options...
guys Posted March 5, 2014 Share Posted March 5, 2014 What did they do back in the time, with the gearbox oil drain bolt that protrudes quite a bit from the bottom of the engine? Quote Link to comment Share on other sites More sharing options...
twinnshock Posted March 5, 2014 Share Posted March 5, 2014 (edited) Hole in alloy plate that aligns with the drain plug. My converted frame/bike (m198) has the lowest part of the bolt approximately 2-3mm above the lower surface. Never has a problem with damage but I do live in East Anglia! Stuart Edited March 5, 2014 by twinnshock Quote Link to comment Share on other sites More sharing options...
badgert4 Posted March 5, 2014 Author Share Posted March 5, 2014 Stuart , Thanks for all the info it's been a big help . I do plan on keeping it all original on the restoration and ditching those plastic mudguards . Thanks again Lee Quote Link to comment Share on other sites More sharing options...
scot taco Posted March 5, 2014 Share Posted March 5, 2014 The rear hub looks like the same one on my 74 Pursang. Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted March 6, 2014 Share Posted March 6, 2014 The hub is the the right one Bultaco used it in 74-75. My M125 has the same hub. It is lighter then the earler ones. Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted March 6, 2014 Share Posted March 6, 2014 (edited) The rear hub is the same as on my Model 124 250cc 1974 & will be correct for your bike. The alloy sump guard conversion has been really well carried out, the whale tail especially is as on my 199A 1980 350. Check the brake drum surfaces they were chromed when new this does come off but can be repaired with a cast iron lining with the rim in place. Alloy guards do really suit the Bultaco bikes but are a little bit pricey if you are riding it. Edited March 6, 2014 by trialsrfun Quote Link to comment Share on other sites More sharing options...
