wacky Posted April 21, 2014 Share Posted April 21, 2014 I have a TY250 Mono fitted with 'Shirt/Grimeca' front disc conversion. Does anyone know what the individual componants are from? Looking to replace the pads and probably the disc but need some guidance on getting the bits. And Yes, I know the brake is worse than the drum but thats what I am stuck with. Quote Link to comment Share on other sites More sharing options...
andy m Posted April 21, 2014 Share Posted April 21, 2014 A decent bike shop should be able to match the pads if you take a pattern in to them , I think EBC have a pattern book. Not sure about the disc. 1 Quote Link to comment Share on other sites More sharing options...
60north Posted April 22, 2014 Share Posted April 22, 2014 hi wacky, the wheel, disc and caliper are taken from the fantic 243. i use ebc fa099 pads, dimensions are 31.5 x 52 x 5.5mm. goldfren 120 pads is another i have used in the past. if you fit a fantic disc the mounting holes will have to be countersunk to allow clearance for the shirty bracket, i fitted a new/old stock disc last year and found no improvment in braking, hope this helps 1 Quote Link to comment Share on other sites More sharing options...
mattylad Posted April 22, 2014 Share Posted April 22, 2014 Fitting a later 4 pot caliper is the solution 1 Quote Link to comment Share on other sites More sharing options...
wacky Posted April 23, 2014 Author Share Posted April 23, 2014 Thanks Chaps, that gives me some ideas to work on..... All Power to the Forums! Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 25, 2014 Share Posted April 25, 2014 I put a yz 125 (1984) front wheel with disc and used the yz master cylinder. Worked excellent and was cheap. Just had an aluminum adapter made that clamped on the front fork. More stopping power than the new 4 pots. Quote Link to comment Share on other sites More sharing options...
