November 1, 201412 yr Author hello guys it is a tidy bike it was a nice bike before just needed some TLC cheers
November 1, 201412 yr Working as a professional motorcycle mechanic for twenty years I've seen a lot of damage done to fork tubes due to over tightening of the pinch bolts. Simply put there is no good reason not to use a torque wrench on all critical fasteners. None! and by critcal fastenrs I'm talking head bolts, engine case nuts and bolts, brake stays , fork stanchions, axle nuts. Any experience you think you have with twisting wrenches and using your elbow as a torque wrench is foolish. I prove this fact year in and year out with apprentice mechanics that think they know only to find out they've been torquing bolts to triple the rated spec damaging threads in engines and forks and brake calipers. Know your torque wrench. Have a torque chart available and use it. Steve
November 1, 201412 yr Author hi i do have a chart up on the wall that i refer to. same with the cylinder head i have a diadram that show the sequence and torque am not heavy handed. same with the clutch case and ignition case. i just wanted to make sure as iv.e not done the 199b yokes before there threaded the other bikes iv'e had have been bolt and nut job. the later yokes look better with the recess for the allen head. sorted now so job done cheers
November 2, 201412 yr Bondy, Great looking bike! We don't see any B models around here, so had no idea about the threaded triple clamps ; looks nice but is an accident waiting to happen IMHO. Have a nice day, Larry
November 2, 201412 yr Author hello Larry it is unlikely anything will happen as the bike dose not get used. thanks for the comments
November 2, 201412 yr Bondy, was only referring to the threaded yokes. Your bikes always look great. Regards Larry
November 5, 201412 yr hello Larry it is unlikely anything will happen as the bike dose not get used. thanks for the comments My comment wasn't far off the mark, if your using it in competiting you would probably have the bolts well below max torque, and if your not ---- it doesn't matter anyway. Edit to say, nice looking bike. Edited November 5, 201412 yr by b40rt
November 5, 201412 yr Author hello b40rt thank you for the comments i will be using the bike only to ply on won't be getting hammered. i only do it for fun just love bultacos.
November 12, 201412 yr Bondy - The matter of threaded yokes must have passed me by until reading your o.p. - ......but there are pics. all over the internet of course to show this feature on late bikes. My own 340 was just 6 years old when I bought it, but had the 199/199a etc. yokes (bolt and nut clamp). Mind you, it did have the slab-sided alloy tank.
November 17, 201412 yr 199b002.jpg Hi Bondy love your bike what paint did you use for the frame ? did you take it back to the bare metal ?
November 17, 201412 yr Author hello stanley no is the Answer to that. i just cleaned and rubbed down with some scotch pad then primed and top coat full gloss in 2 pack will have a look what the code is. i got it mixed at my local paint shop wouldn't bother going to halfords there paint is crap. this stuff i used is good paint. cheers bondy.
November 18, 201412 yr Muchas gracias for the info just about got my 77 350 finnished (decals mudguards final polish ) and have a 78 350 waiting to restore, what year is your pictured bike ?
November 19, 201411 yr Author stanley the paint i used on the 199B is 9016 i got it in full gloss but you can have it in semi gloss or matt in 2 pk good stuff
