Mystery 348 Motoplat..
So.. I ordered a 'Montesa' rotor puller from Sammy Miller, which is (by my measurement) 30mm.
However, my 348 has had a number of upgrades over its life, including a Motoplat Mini 6 Electronic ignition.. which I'll be posting off to Bradford Ignitions as soon as I can get the rotor off..
The crank end makes measurement in-situ with calipers tricky, but I make the internal thread size about 26mm, so I guess my question is:
Did / do any Motoplat Electronic rotors come with puller thread sizes close to (either side) of 26mm? In other words, am I safe buying a generic 26 x 1.5mm puller- or could my mystery rotor possibly be 25mm- or 27mm, etc..?
Duncan
Motoplat ignition fly wheel pullers are double ended 27mm & 30mm
Mini 6 flywheels use a strange puller. It isn't the 27 mm of the smaller montys, but a 26 mm one if I don't remember badly.
It's a light electronic flywheel. Maybe too light for a trials bike, imho.
Hi Kingscorpion- thanks for the tip. There's no reason to believe the rotor & stator came from another Montesa- presumably just some other 70's/80's European bike.
Steve at Bradford Ignitions ('Motoplat UK') said the same thing- that the Mini 6 was maybe a little light for a trial bike- I guess because it was originally fitted to an Enduro / MX.. however mine has a heavy brass 'wedding ring' band sweated onto the outside of the rotor to add some weight.
You said 26mm.. 1.5 pitch and Right Hand thread..?
I have a beta zero with a mini6 ignition. i have 2 flywheels for it, one is a lot lighter than the other. The heavier of the 2 is quite a lump, so I would say plenty heavy enough for a trials bike, if you want, I can weigh it... just so that you know if one would be heavy enough if you wanted to source one. I can confirm that the thread is 26mm / 1.5 pitch normal thread direction. Sorry for not replying before, but I've had trouble logging in
Thanks, BogHopper
The P.O. kindly got in touch and confirmed the spec. It has a Mini 6 set up- from a Villers 210 classic kart (the UK's longest running kart class, apparently)
Luckily, my online researches had led me to a 26mm x 1.50mm R/H puller, which I've already ordered and is on the way.
The P.O. had a whacking great brass weighting ring turned up and sweated onto the rotor; and IMHO the bike has bags of bottom end grunt.
Thanks all
Losing the will to live here..
My mystery 348 Motoplat electronic rotor doesn't take a 'Montesa standard' 30mm puller- and the 26mm x 1.5mm R/H puller I just ordered is fractionally too small. Aaarrgh!!!
I don't want to use a 2/3 leg puller, for fear of messing up the sweated-on weight band, so before I try for third time lucky and order up a 27mm x 1.25mm R/H puller from BVM, has anyone got any further suggestions or input?
The P.O. tells me my Mini 6 is 'the same as fitted to a Villiers 210 kart engine'.. although I haven't managed to find any rotor / puller specs for same online.
Q) Has anyone ever come across a Motoplat rotor with a L/H thread- (or is the BVM unit likely to be correct)
Thanks again in advance..
i had to get a 26x1.5 for a 307 with electronic ignition there is a set of around 12 pullers on ebay for not much more than what one costs
I have set like this... This guy knows what he's talking about. It's worth a try, they have many combinations of sizes / thread direction.
I gave up on finding an internal puller to fit, and went with a 3-leg. It's very slightly dented the brass weighting ring, but I doubt it'll significantly affect balance.
Stator & coil are away with Steve at Bradford Ignitions, so hopefully I'll be trialling again soon..
