Mooses
I have had a look , but can't find the info, I am sure there was talk of a trials moose , are they available, half way through an Enfield rigid build, and was thinking a puncture proof rear would be handy...
No such thing as far as I know as they can't get them to deform as a trials tyre has to.
Normal moose may be ok as although they're 14 psi equivalent, the weight of a rigid Ariel may flatten the profile and put some deformity in it... ;)
4 security bolts,thik Enduro or MX Tube that will do.
Remove cores to make them softer.
Cores?    they were just a solid rubber moulding when I used to use them, no cores
Nuetech makes a run flat system called Tubliss, Its a bladder inflated to 100lbs. and seals the tire to the rim. I run it in my evo. The only thing I wasn't fond of was drilling a new stemhole for their proprietary rim lock. Punctures are repaired with tire plugs or you can run tire sealant but I get by without it.
