Rear Wheel Change
lewis_gasgas
Don't forget to get a YOU HAVE USED WORDS OR A PHRASE WHICH ARE NOT PERMITTED ON THIS WEBSITE. PLEASE DELETE YOUR POST/TOPIC. DO NOT TRY TO CIRCUMVENT THE FILTERS IN PLACE ON THIS WEBSITE beader they are essential.
The rypusa site is the biz
I will certainly second the beader, I cannot say how many times I wrestled with these things and straps, and tiger tanks, and other assorted deals. Once you get and use one, you will wonder why on earth you ever did without.
But, if you do not have one, Put spacers (in America a can of beer is perfect) between the two beads and let set overnight, then when you pull the beer out, rapidly mount the tire prior to the beads coming back together.
you dont need a beader if you have compressed air.
with the compressed air you put more in than is coming out and eventually it goes pop on to the rim(with a very loud bang)
James
James
I cannot stand it, just how many of these have you done may I ask? Have you ever done a new michelin that has been sitting in a warehouse for a bit?
Lew Gasgas...get a yommee beader..they;re great..probably the biggest problem you'll have is beading it..the rest is easy...and you MIGHT even find that if you go down to the local tyre shop, even THEY might struggle to bead it..if they are not used to doing trials tyres! :rolleyes:
i've probably done 20 + trials rears and god knows how many street tires (more than a thousand)
no issue here 'cept for a few stupidly wide race tires
just my 2 cents
