  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
Change Piston And Piston Springs On A Regular Basis 1998 Gas Gas Tx 320?
The previous owner told me that i should change/check the piston and piston springs
I talked to the company that sells Gas Gas trial motorbike here where i live and they told me that i did not need to cange piston or piston rings on  a Gas Gas
What do you think about this?
Edited by thesaint
no need to change them unless there is a problem, they should last years :thumbup: (if you keep your air-filter clean & oiled)
Edited by suzuki250
as said above, do a compression first and as a ballpark figure from when i rebuilt my engine was 195psi after rebuild, and 120psi before rebuild. the piston and rings are no longer available from gasgas, but you can fit S3 piston then have cylinder re-plated to suit new piston
