biffsgasgas Posted August 26, 2015 Share Posted August 26, 2015 So I have been told to shave down the ty175 flywheel weight. Then i have been told to remove it. Then told to not touch it. So what has been done out there? Removal Shaved or left alone? --Biff Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 26, 2015 Share Posted August 26, 2015 It depends on how much the motor has been hotted-up, and the riding technique and standard of the rider. I have a fairly-well hotted up 205cc motor in one of my TY175s and there is no way I would want to reduce the flywheel weight from standard, but on another TY175 with standard performance motor I think the little bit of lightening it has had has helped it. There is no one perfect flywheel weight for any motor, because flywheel effect is a trade-off and everyone rides using different technique 2 Quote Link to comment Share on other sites More sharing options...
goudrons Posted August 26, 2015 Share Posted August 26, 2015 The talk is a lighter flywheel allows the motor to spin up quicker as there's less mass for the motor to move and in theory it's correct. F1 cars have very little weight on the engine so they spin up their rpm very quickly. But the mass of the flywheel keeps the engine spinning at low rpm and will store some of the engines energy. (which is why you can shut the throttle off before you reach the top of a climb and still make the top or rev up and dump the clutch for a hop) Again, little weight causes F1 cars not to idle very well so they sit in pit stops with screaming rpms as they won't idle very slowly. So lightening what you have will cause the motor to spin up slightly quicker, not store the same amount of energy for off throttle maneuvers and will stall at slower rpms a lot easier. If you are going to experiment, pick up another flywheel and take small amounts at a time. 1 Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted August 26, 2015 Author Share Posted August 26, 2015 Yea I am very familiar with the purpose of the flywheel and the items that you are pointing out. So my plan is to install boysens and a pwk24 flatslide. I will mildly port the engine and measure the squish. I don't think i want to remove much. Maybe none at all. FYI most F1 engines have nothing but a clutch in the way of a flywheel. I feel that the ty175 is over weighted however i also love how that lil engine can chug so my head is looking for what that balance is. --Biff Quote Link to comment Share on other sites More sharing options...
spinner Posted August 27, 2015 Share Posted August 27, 2015 Biff I have 3 flywheels that I had been experimenting with, stock about 6.25 lbs a 5 lbs one and one around 4 lbs. I've have been using the 4 lbs one and will not go back the the others. The bike I rode at the Nebraska National had the light flywheel on it, the bike doesn't stall and idles smooth.I'm still using points with the condensor mounted under the tank ,the cylinder has been ported and the squish is tighter. I should have let you ride it at the national you would have liked it. Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted August 27, 2015 Author Share Posted August 27, 2015 (edited) Biff I have 3 flywheels that I had been experimenting with, stock about 6.25 lbs a 5 lbs one and one around 4 lbs. I've have been using the 4 lbs one and will not go back the the others. The bike I rode at the Nebraska National had the light flywheel on it, the bike doesn't stall and idles smooth.I'm still using points with the condensor mounted under the tank ,the cylinder has been ported and the squish is tighter. I should have let you ride it at the national you would have liked it. That's what I am looking for. Thanks! I have three whole bikes in the house now and I have some room to play with them. Thanks for the info! Next time sir. I will not let you ride off with out me trying --Biff Edited August 27, 2015 by biffsgasgas Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 27, 2015 Share Posted August 27, 2015 From where are you removing the metal? Round the circumference or from the face, it makes a big difference to the effect. 1 Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted August 29, 2015 Author Share Posted August 29, 2015 I would be more inclined to remove from the face. Obviously that affects the moment arm of inertia. I have the weight seperated. I will probably take it to one of the most natural trials riders I have met who quit the sport to build huge pulling trucks. If your ever in Detroit I will show you the shop. --Biff 1 Quote Link to comment Share on other sites More sharing options...
