November 6, 201511 yr Was wondering if it's possible to replace the 2 piece rear brake M/Cyl on the 2010 Evo to the inbuilt reservoir M/Cyl from the >2015 bikes? Edited November 6, 201511 yr by jml
November 6, 201511 yr The new master cylinder is crap. We have had to rebuild several already. The fluid comes out black as night.
November 7, 201511 yr lineaway, regardless of bike brand most of the rear brake components are Braktec. The Braktec made components do not seem to be as good as the AJP brand were in the past.
November 7, 201511 yr Well I`ve known that from the start, but the masses seem to be blinded by the bling. All the old hydraulics were much better. Pretty sad that for years now the riders in the know have swapped out the parts right away.
November 9, 201511 yr Author Well I`ve known that from the start, but the masses seem to be blinded by the bling. All the old hydraulics were much better. Pretty sad that for years now the riders in the know have swapped out the parts right away. So if I was going to replace the current M/Cyl is there a better designed one that can be fitted or should I just replace it like for like?
