markb21162 Posted January 19, 2016 Author Share Posted January 19, 2016 (edited) Do u no AV some one or some where a can get the lid for the air box or a hole air box bud Edited January 19, 2016 by markb21162 Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 21, 2016 Author Share Posted January 21, 2016 Well was out at the bike to day sorting the last few thing on it and decided that al try kick it over so way a went and shock 4 kicks and way it went so well happy and it's all down to the advice from u guys so just want to say thanks for the advice and help Quote Link to comment Share on other sites More sharing options...
mspenz Posted January 21, 2016 Share Posted January 21, 2016 Well done! If you are having problems bleeding the back brake make sure that the master cylinder piston and seals are in decent condition, also worth rotating the M/C piston through 180 degrees as they seem to wear more on one side due to them being pressed at a slight angle by the pedal. Take the brake pads out and clamp the pistons fully home, this stops any sneaky bubbles getting trapped behind and makes bleeding easier. Bleed them as best as you can (gravity feed for 20mins first) and then leave overnight with the brake pedal / lever cable strapped at the position when pressure is coming on (not fully down), this can help squeeze out any air still in the system. Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 25, 2016 Author Share Posted January 25, 2016 What 2 stroke mix do I want to use with this bike Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 25, 2016 Author Share Posted January 25, 2016 Really m8 will the motocross stuff do Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 25, 2016 Author Share Posted January 25, 2016 http://www.opieoils.co.uk/images/VARIANT/small/1075.png Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 25, 2016 Author Share Posted January 25, 2016 http://thumbs1.ebaystatic.com/d/l225/m/mMSWvfvIp4dcE78Vlw8GCHA.jpg Sorry it's not that one its this one Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 25, 2016 Author Share Posted January 25, 2016 Cool thanks Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 25, 2016 Author Share Posted January 25, 2016 Ov got the second 1 that a put up m8 Quote Link to comment Share on other sites More sharing options...
copemech Posted January 26, 2016 Share Posted January 26, 2016 Semi synthetic oils have and do work fine in a trials application as long as the quality is good. The ratios do not change from full synthetic and 80:1 is fine. The bikes are not highly stressed and unless one is road riding at high sustained speed and revs I would not increase the ratio of either as the performance is comparable in all but the most highly stressed conditions and temps.. which you are unlikely to achieve on a trials bike. 2 Quote Link to comment Share on other sites More sharing options...
madmostin Posted January 26, 2016 Share Posted January 26, 2016 Castro 747 Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 26, 2016 Author Share Posted January 26, 2016 (edited) Help please a can't get my clutch to work Am bleeding and bleeding but the leaver just gets stiff Edited January 26, 2016 by markb21162 Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 26, 2016 Author Share Posted January 26, 2016 Done it about 6 times m8 as soon as it all looks good u lock the nipple and when u go back to the leaver it's really stiff Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 26, 2016 Author Share Posted January 26, 2016 No just gets stiff and the clutch is not working Quote Link to comment Share on other sites More sharing options...
markb21162 Posted January 26, 2016 Author Share Posted January 26, 2016 (edited) Al have a look at the tomorrow m8 that's me done for the night that's all AV left to do then it's finished. At last Edited January 26, 2016 by markb21162 Quote Link to comment Share on other sites More sharing options...
