manxmann3 Posted July 5, 2016 Share Posted July 5, 2016 Hi Compared to my 2012 beta evo the mont front brake is poor I don't mind spending a few quid of better brake. I'm not too worried on sticking to original montesa specs Can brand new modern gasgas,sherco or others brakes fit straight on? Thanks Quote Link to comment Share on other sites More sharing options...
reggie Posted July 5, 2016 Share Posted July 5, 2016 The bolt pattern used to mount most of the front brake calipers is the same whether they be 2 piston or 4 piston. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted July 6, 2016 Share Posted July 6, 2016 If you can't get Goldfren pads easy the Galfer red pads get great reviews. and I agree, clean, flush, and scotch or emery cloth, and ride in the pads and you will likely find them better than ever. Quote Link to comment Share on other sites More sharing options...
copemech Posted July 6, 2016 Share Posted July 6, 2016 " flush out all the old brake fluid from the system,refill with new and bleed all the air out until the lever has a solid feel,then fit some new Goldfren pads with S33 pad material." This DOES NOT mean flush the system with brake cleaner! Simply exchange the fluid, if you must. Many times the brakes will firm right up and perform well if the pads are not contaminated by simply dragging the brake for a bit to get some heat into them, then steaming them off by dousing with water. From a bottle! 1 Quote Link to comment Share on other sites More sharing options...
manxmann3 Posted July 8, 2016 Author Share Posted July 8, 2016 I've scrubbed up the disk and pads, new fluid in too. Put some heat into the pads and cooled with water Still hardly powerful I think a Honda nissin master cylinder might be the way to go? Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 9, 2016 Share Posted July 9, 2016 if you cant get the set up right a master cylinder might not help. Waste your money and prove it either way? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted July 9, 2016 Share Posted July 9, 2016 Dose everything seem like it's working well other than just not braking well? If so it is likely bad pads... Or it is more like the lever is great during the bleeding process but just doesn't seem to work well afterwards, hard pull, stiff? If so its the calipers not the master. Or the lever is all soft when your done? Then it's likely the master. There is no guarantee I am correct on cause but my past experience with brakes I would expect this to be the case... And good luck. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted July 10, 2016 Share Posted July 10, 2016 I ve had 8 or so 315 through my hands recently and ive had lots of various things that werent 100% but never thought the front brake master needed changing 1 Quote Link to comment Share on other sites More sharing options...
