tlr 200 tank shelter inner tank
does any one know where i can get another polyethylene inner tank for my shelter as mine is leaking
I've been looking for one for ages but never found one. (nothing on acrebis web site)
I'm sure there is a market for somebody to make ally ones as there are shelters available at reasonable prices or you can make a shelter easy enough -the inner tank is a bit more technical !!
Try the following:
1. Shedworks.  Paul 07761408060. Or paul.cowley@live.co.uk
Mike Pearce, Winchester.  Found on Honda TLR Facebook page.
Edited by andy
2 names removed. Not permitted on Trials Central
  • 2 weeks later...
hi all thanks
for the reply's i now have decided to make a  alloy tank done the pattern form my tank having them laser cut in 2mm alloy to my template so its the exact replica of the plastic tank then i will  bend them and Tig weld them up in work as i am a engineer CAD designer with use of machine shop  ,I have done a design so its less welding as possible so make it will look very neat as the finished item
Edited by pumacad
28 minutes ago, pumacad said:
hi all thanks
Do you fancy sharing cad files and some photos when it's done.
i have sone facilities at my disposal and would at least like to do similar - might have to sun out the welding.
stick designs on eBay even ??
swap you for a 2d cad file for a 4rt bash plate I did !!?!?
Hi jim
I know who you are as i been to many local neath trials and seen you riding your TLR  and monty ,If you want if you want i use mine as a prototype first and if works well i give it to you to try on your bike to see if you happy with fit and if you want i make you one also as you are a local rider
42 minutes ago, pumacad said:
Hi jim
Top man
much appreciated
You will have to reveal who you are !!
cheers
jimmy
