Tr280i Diagnostic Software
Make sure to check the COM port on your driver.  Then match that.  (See my picture)
  • Replies 167
  • Views 56.9k
Most Popular Posts
  • Hi ricarver, I haven't read all the posts here so am not sure what your original problem is, but seems to be that you can't start your bike. While these bikes have been difficult at times to fire
  • not to stray too far off topic but I just have to comment on how spotlessly clean kiwishauns Ossa is
  • Mickyzce, check your PM!
The COM port matches, plus have previously tried bridging blue & green but still no luck.  I think I am running out of variables to try, so may need to ponder this and try again later.  Thanks all for your kind input.
BTW - my bike is a 2015 TRi 300 with my old 2012 Explorer plastics, tank & seat on it.  Like my other bikes it gets a good pampering to keep it in new condition and operating as best as it possibly can.
Does your 300 have the Termi exhaust?   I have not tried fitting my Explorer subframe on my 300 factory to see if it clears the exhaust or not.
Standard exhaust on the TRI 300.
the Explorer parts fit on the 300 nicely without any modification required.
BTW, I'm watching as you all arrive at a solution for this communication issue. I'm not the most computer literate so, really just haven't had anything to contribute.
Fingers crossed that you solve it.
"not to stray too far off topic but I just have to comment on how spotlessly clean kiwishauns Ossa is"
I was thinking he must be working on a new bike.
Hi,  Phil,
It looks like ossabc63 has found a cable solution.  Have a look under the topic 'Ossa TR280 Software'.
Hi All,
Just an update.
I received the new FTDI serial TTL-232 USB Cable over the weekend and grafted the terminal plug from one of my earlier failed FTDI cables and plugged it into my TRi300.  It works !
See attached photo's.
Thanks.
I found an oem cable for sale (minus the software) on the weekend.But the price is over the moon.
Where did you find the proper connector that plugs into the bike’s diagnostic port?
  I have the pins, but cannot find the plug.
mark
P.S. - grind of the locking tab on the female half body.  This reduces the pressure when trying to detach the diagnostic cable from the bikes connector plug.  And when detaching always pull on the connector plug not the wires which are very delicate.
Corsa technic. Com they are hm sealed comes with terminals and seals great website. Cheers
