chappo Posted April 14, 2017 Author Share Posted April 14, 2017 Thanks but wouldn't have a clue where to start with that. ?? Quote Link to comment Share on other sites More sharing options...
dadof2 Posted April 14, 2017 Share Posted April 14, 2017 http://www.overlandtrail.biz/Manual Montesa 4RT 05.pdf See section 6 (electrical) it has some self diagnosis functions regarding the sensors I mentioned. Also some sensor resistance values 1 Quote Link to comment Share on other sites More sharing options...
jimmyl Posted April 15, 2017 Share Posted April 15, 2017 A fresh oiled filters will stop the bike from starting especially if you us an aerosol type. spraying wd40 ( other brands available) around the mudguard intake area when running bike after washing causes revs to drop so they can be confused. Quote Link to comment Share on other sites More sharing options...
chappo Posted April 24, 2017 Author Share Posted April 24, 2017 Thanks for all the help chaps. The aftermarket breather was partly to blame, the ball bearing had seized in its alumium body in the closed position so creating a vacuum. WD 40 ( other similar brands will also do the job ) overnight released it, no problem. Kept the same plug but cleaned and lightly oiled the air filter and it seemed to start better and ran fine. So I'm at fault for putting to much oil in the air filter on cleaning. Ive also got to add I opened every electrical connector I could find and gave them a thorough clean. One of those could also have contributed to its better running. Thanks . PS jrsunt, nice to see you flying the Montesa Flag at the BTC in Cumbria the other weekend, yours sounded well and some smooth riding, nice to watch. I think it was you??!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted April 24, 2017 Share Posted April 24, 2017 Any update then Chappo? Quote Link to comment Share on other sites More sharing options...
jrsunt Posted April 24, 2017 Share Posted April 24, 2017 Thanks chappo. Not much smooth riding, you must have seen my one and only good ride! At least the weather was good though! 1 Quote Link to comment Share on other sites More sharing options...
chappo Posted April 24, 2017 Author Share Posted April 24, 2017 8 hours ago, 2stroke4stroke said: Any update then Chappo? Put it above your comment 2stroke4stroke. Quote Link to comment Share on other sites More sharing options...
chappo Posted April 24, 2017 Author Share Posted April 24, 2017 Hi jrsunt, Id be happy riding as badly as you. ??. Not sure if your doing the SSDT, but going to watch the first two days. We'll give you a cheer if we see you, only if you go clean of course. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted April 24, 2017 Share Posted April 24, 2017 (edited) I must have missed a page somewhere along the line. Edited April 24, 2017 by 2stroke4stroke 1 Quote Link to comment Share on other sites More sharing options...
