Engine oil
Hello Guys help needed please just bought a 07 Scorpa SY 250 can you tell me what Engine oil is best also is it all 1 oil clutch and gear oil? cheers bondy.
Sorry
It’s the same oil for clutch & gearbox, drain from underneath but be careful as drain bolts made from toffee
upgrade it with the one on trials & tribulation on similar
thanks
3 hours ago, leeanthonycook said:
Sorry
thanks
Plus, the drain bolt is kind of tilted, so the socket and extension need to be at an angle relative to vertical during removal or installation.
cheers guys mines 2 stroke what oil do you reomend ?
2005 Scorpa SY250R, the gearbox is serviced with Shell Rotella T4 15w40, the premix oil I went with Maxima Formula K2 @ 50:1 premix ratio.
IS PUTOLINE light ATF GEAR OIL OK??????????????????
