Beta evo 300 2014
Bike started to idle funny bit up and down then overheated and now wont start, its got fuel, spark,  carb cleaned, compressions dropped aswell
If it's blown a lot of coolant out check the head gasket (maybe O Rings) also.Are you sure your fuel/ oil mixture was good and it hasn't nipped up as suggested.Was it being used hard just before it stopped,if it was idling it seems unlikely it seized upIf all the above checks out ok I'd suspect the stator
Don't know how you would check it now, but did you use neat Petrol instead of the Petr-Oil Mix..?
