Varlo Posted August 29, 2018 Share Posted August 29, 2018 Hi, I’m replacing fork seals on my fantic 200, what’s best? 2 seals in each leg or 1 seal & spacer Quote Link to comment Share on other sites More sharing options...
bullylover Posted August 29, 2018 Share Posted August 29, 2018 If they are 35mm Betors then use KTM SX 65 from 2002 to 2009 seals. These are Ariette seals with a double lip and even come with some seal grease to cut friction from new. You only need one seal a side with these. I use them in all my Bultacos and they are brilliant. Graham. Quote Link to comment Share on other sites More sharing options...
Varlo Posted August 29, 2018 Author Share Posted August 29, 2018 Hi Graham, yes there 35mm, do you use spacers to replace the second seal? carl Quote Link to comment Share on other sites More sharing options...
b40rt Posted August 29, 2018 Share Posted August 29, 2018 Think Fantics had marzzochi's ? If so use 2 IMO. 1 Quote Link to comment Share on other sites More sharing options...
baldilocks Posted August 31, 2018 Share Posted August 31, 2018 Some had Betors, similar to the Betors fitted to my twinshock Beta TR240. One of Birketts early 200s did but not sure if they were on production bikes? Quote Link to comment Share on other sites More sharing options...
Varlo Posted September 2, 2018 Author Share Posted September 2, 2018 Mine are betors, with double pinch bolts, I’ve taken them apart but the stanctions go tight in the right leg about 3 1/4 way down. Both stanctions ok in other leg ! Quote Link to comment Share on other sites More sharing options...
