September 17, 20188 yr 2 hours ago, KompeMax said: My back trial tire leaks air What can it be? Its either a puncture or this https://youtu.be/k290LeBasws
September 17, 20188 yr 54 minutes ago, KompeMax said: My back trial tire leaks air What can it be? Could be a lot of things... a lot of older bikes have a rim strip that might need cleaning or replacing and if so I would suggest considering a smear of RVT sealant around the edges to help. could be the valve stem has a leak in the valve core or crack if the valve core replacement should fix it, of stem is cracked it’s a pull the tire job to replace or find one of those quickStem replacements. You could have a torn bead on the tire, or a poorly fitting tire as there has been a few reports of some tires not working with some wheels. theres a few possible things. good luck
September 17, 20188 yr 2 hours ago, greychapel said: bath of water should show where its leaking wack the pressure uo to like 40 psi plus put it in clean (ish) soapy water and rotate - you should then see a stream of bubbles from the point of failure. the answer to this will guide you on how to fix it - could be cracked rim, leaking spoke/rim tape, the valve, the seat of the tubeless tyre on the rim or even just a puncture
September 18, 20188 yr Author 14 hours ago, oni nou said: Its either a puncture or this https://youtu.be/k290LeBasws Its the back tire i think im to fat maybe
