October 8, 20188 yr A Fantic 309 found it's way into my garage, does any one have some information on it? Parts fische and manual would be of great help
October 9, 20188 yr Author I've tried to find his web site but it seems to be gone, I have found all the parts that I need I'm looking more specific information
October 9, 20188 yr I had a 305 and the manual was in Italian. Watch out for the skidplate bending and cracking the cases and chain coming off and breaking the case.
October 10, 20188 yr This is for a 307 but as they're pretty similar to 309 might give you information you need. Fantic_307_parts_list.pdf Edited October 10, 20188 yr by fantic240motor
October 31, 20187 yr I would say watch out for it being a complete rocket ship, would give a decent motocrosser a run for its money.... well thats how I felt about it anyway, didn t stay long in the garage, big big section bike.
November 1, 20187 yr The 307 and 309 are virtually identical. As has been mentioned the exhaust is different the front forks have different dampers and it has a smaller diameter rear disc although it uses the same calliper so the pads are too big and you get a step at the top of the pads as they wear. Two other things to watch out for is the rear subframe can get worn through where your boots rub against I put some thick rubber tube over it to protect it and the lightweight swing arm spindle is very delicate! It was brought out the same year as the first KRoo and shares the same colour scheme. Love my one had it from new. Still think the engine is better the the KRoo was.
