April 21, 20197 yr 2017 gg txt 250 with the tech aluminum fork only compresses half way and stops. I installed a stiffer spring then noticed the issue. I put the old spring in or no spring at all and get the same result. thanks! glenn
April 21, 20197 yr Author Thanks lineaway, I don’t think it’s too much oil because it bottoms out very solid. Is the bottom bolt on the same side as the spring?
April 25, 20197 yr bottom cone not seated propelly??? This fork need a completly disasembly https://www.youtube.com/watch?v=fOPho-XoVds
May 13, 20197 yr Turns out it had double the amount of oil it should have had in the rebound leg. It was like this brand new from the factory.
May 13, 20197 yr thanks for returning how situation ended. This is greath for knowlege base of this forum
