Evo Linkage Guard
Evening All
Has anyone fitted one of these Jitsie rear suspension linkage guards?  What does it attach to - rear engine bolt? and under sumpguard? and has anyone fitted one to a newer Evo (2020 4T)
Thanks in advance for any answers.
Edited by John54
New pic
I just had a look under my 2010 evo 4t 250.... I can't see any obvious place except perhaps onto the linkage bolts themselves - not sure how far between the sides of the bracket on your guard, but they look quite large diameter holes, so maybe?
Gas gas one goes between sump guard and frame if that helps
Thanks for the info guys. Someone told me that the linkage guard comes standard on the newer 2 stroke EVO but not on the 4 stroke
Us four stroke Beta riders been left out again.
In the picture you attached it says 4T 09->13 so surely that means its not a simple bolt on to a 2020
I contacted Jitsie who said the frame design hasn’t really changed and recon it should fit. How I don’t know.
  • 1 month later...
Cable ties of course!!!
Good old cable ties. I gave up in the end and bought a genuine Beta one (£9.75) that’s for 2T but fits straight onto 4T only had to trim a piece off rear of rubber cushion between sumpguard and engine.
