My Suzuki DS 185
So I got the TS250 flywheel and it's the same as the original (but nicer) so I found one for a '74 RL250 and made the purchase. It's definitely thicker/bigger. The magnets look a little different so Ill tune the bike with the TS250 unit which is in much better condition than the original 185 flywheel.
51582273526_dab570f358_h.jpgUntitled by barnstormerbikes, on Flickr
51582497348_34567e8057_h.jpgUntitled by barnstormerbikes, on Flickr
I built the bits to attach the right side cover and put my new NJB shocks on for a test fit.
51582944429_c73f07b5f5_h.jpgUntitled by barnstormerbikes, on Flickr
I started hammering a piece of sheet for the seat base and like the look so far.
51581445492_1aeb487bd7_h.jpg by barnstormerbikes, on Flickr
51581445547_18cf9d2e86_h.jpgUntitled by barnstormerbikes, on Flickr
  • Replies 89
  • Views 25k
Most Popular Posts
  • I straightened the shifter shaft and filled the worn/gouged spots with silicon bronze, filed it down and machined a new "hole" to bond in the pocket. I lost a little bit of the OD of the shaft and got
  • The rod came in so I rebuilt the crank.  I used centers to hold the ends (ends in good shape) and put my indicator on the bearing surfaces and got it a little better that stock. I set the rod end play
  • There is a lot of room between the flywheel and cover. Once the flywheel weight is correct Ill probably give it a shave. Untitled by barnstormerbikes, on Flickr Untitled by barnstormerbikes
I had a few very productive hours and got the seat pan done. Also held down with a Dzus fastener.  It's a little lumpy but perfectly suitable for the application. I used 1.5 mm for seat and side panels so they are very light. I took a lot of photos. Now that the big things are done I can clean up my work bench and assemble the engine.
51589940523_d1e167a788_h.jpgUntitled by barnstormerbikes, on Flickr
51590619090_c48d1e0794_h.jpgUntitled by barnstormerbikes, on Flickr
51589725371_ce6464e81d_h.jpgUntitled by barnstormerbikes, on Flickr
51588893592_c48f6183c9_h.jpgUntitled by barnstormerbikes, on Flickr
I would not put very much saddle on that at all,maybe a outline of one in black paint (-;
I like to be able to lay the bike over in turns and have the saddle just below knee level (have no idea how tall you are) so you can get maximum lean while still having your body vertical.
I lowered some foot pegs too far on a bike one time and tilting the bike over would drag on my thigh and pull my weight to the inside of the tire contact patch, it made it more difficult to accurately guide myself in turns.
And oh yea, the seat pan works really well visually with the side panels!
Edited by htrdoug
I was thinking about using colored adhesive backed kitchen shelf paper for a saddle. That is pretty minimal! I have been weighing some of the original and what I am using and haven't made much progress weight-wise. The alloy body parts should help.
The bike looks a little wide just below the saddle but the peg width is narrower than my current bike by 3" so Ill see.  I am super tempted to assemble the rolling chassis at this point to see how it feels with pegs.  I have been practicing leaning the bike myself and am only doing it in flatter turns right now on my stock 72 OSSA, possible because the head angle is quite slack perhaps 64 or so the steering ratio is quite slow when leaned on a hillside. I am 5'10", 165 lbs.
On 10/15/2021 at 5:46 PM, Ftwelder said:
"I was thinking about using colored adhesive backed kitchen shelf paper for a saddle."
I used closed cell, adhesive backed neoprene foam sheets like these:https://www.amazon.com/Sheets-Adhesive-Neoprene-Insulation-Vibration/dp/B08P1W9QQD/ref=pd_lpo_2?pd_rd_i=B08P1W9QQD&th=1 . I went with 1/8" thick but 1/4" would work too. Easy to trim and looks the part.
Edited by stevec
The RL flywheel is the same as the other two except for the ring pressed on the outer circumference which makes the diameter about the same as my outer cover. I ground an old crank bearing to slip in the case bore to check mounting depth with a piece of modeling clay and I have around 19mm of side clearance so Ill draw something up and get a CNC lathe guy so spin up a weight that engages the TS 250 flywheel and mounts to the puller holes and is no larger than the stock flywheel. So now we know I can add weight and also make the motor narrower. All good.
51604418008_9c3af825ca_h.jpgUntitled by barnstormerbikes, on Flickr
51604417998_3a7d6d7ea3_h.jpgUntitled by barnstormerbikes, on Flickr
51605082310_fbf6b8056e_h.jpgUntitled by barnstormerbikes, on Flickr
That odd grey thing in the bottom right corner of the last image is a soft lead weight I use for a hammer on the motor internals.
That looks nice! wear a cyclist bib shorts under my pants but will probably go bareback before adding anything. I used a 3/8' thick closed cell neoprene floormat on the OSSA and it needs to be cut back..
Edited by Ftwelder
I drew up a flywheel weight that should fit in the space and add some inertia. Next thing was to add a port to lube the crank bearing. I opened up the forced oiling port a bit and drilled through from the transfer port to the stock forced oiling port. I hope it works. This it the work site.
51629922315_e13029ec62_h.jpgUntitled by barnstormerbikes, on Flickr
I drilled through to the original hole and created a funnel to guide some mix down the hole. It might work.
51629922300_5de12c731d_h.jpgUntitled by barnstormerbikes, on Flickr
I noticed so cracks around the shifter boss.
51632452364_db912dd7c7_h.jpgUntitled by barnstormerbikes, on Flickr
Exploring a bit it looks like the shifter took a big hit.
51630983182_d7c213004c_h.jpgUntitled by barnstormerbikes, on Flickr
I had a struggle removing the trans shaft bearing and ended up welding in a nut to attach a slide hammer. Yes. I tried the hydraulic method first.
51632656610_754648f14b_h.jpgUntitled by barnstormerbikes, on Flickr
51632452374_ce6f2c2d3a_h.jpgUntitled by barnstormerbikes, on Flickr
I guess I have to weld a boss inside the case to support the shift shaft.
I used a slide hammer, not the end of the bolt. 😁 and it came right out.
Edited by Ftwelder
I straightened the shifter shaft and filled the worn/gouged spots with silicon bronze, filed it down and machined a new "hole" to bond in the pocket. I lost a little bit of the OD of the shaft and got lucky finding an undersized reamer in the stash and got a good fit.
51643153480_641fea2335_h.jpgUntitled by barnstormerbikes, on Flickr
51642519593_8a6b1dec2f_h.jpgUntitled by barnstormerbikes, on Flickr
51645983295_9a640573c0_h.jpgUntitled by barnstormerbikes, on Flickr
I thought about using bronze for the bushing but it's soaking in gear oil so I passed.
51645983420_5bb218cfa0_h.jpgUntitled by barnstormerbikes, on Flickr
I may have mentioned I had found another used cylinder/piston in great shape and figured now was a good time to put it into play. I made a double-wall spigot to get a good pipe seal (a good bit of work) and set out to delete the original feature in the stock cylinder.
51645129156_29da33fe49_h.jpgUntitled by barnstormerbikes, on Flickr
51645786719_ab8cc9040c_h.jpgUntitled by barnstormerbikes, on Flickr
I added a few layers of 4043 and hopefully didn't get any low spots.
51645786674_43db520ab9_h.jpgUntitled by barnstormerbikes, on Flickr
Grind to taste!
51648817525_8d2741d325_h.jpgUntitled by barnstormerbikes, on Flickr
Inching closer! Thanks for looking.
Edited by Ftwelder
duplicate photo
  • 3 weeks later...
I have made more progress and thought I would share. I got the cylinder and head back from cleaning and they look pretty shiny. Ill probably need to age in dish soap get it looking better.
51696788899_78c0a297a3_h.jpgUntitled by barnstormerbikes, on Flickr
I have been trying to educate myself on the workings of the crankshaft oiling system. I have my original crank (badly rusted) and another ebay crank assembly to work with. I removed the LH bearing from the ebay crank and recovered the oil slinger which seemed be damaged though I thought I was careful. I then had to resort to extreme measures to remove the bearing from the original crank.
51696789019_7cb03ba275_h.jpgUntitled by barnstormerbikes, on Flickr
51696110991_e121b9efda_h.jpgUntitled by barnstormerbikes, on Flickr
This evidence combined with the plastic seal that came on my new LH bearing (and no plastic seals in original bearing gave witness to a number of problems with the system (though it's clearly quite functional) The system takes a portion of the oil and introduces it to the intake stream (like pre-mix) and another ration is delivered to a bearing that deliverers raw oil to an exposed lower rod bearing. Once used the pure oil is flung around to various places depending on RPM and air movement. I don't see a need for any part of it if you delete all of it.  I added a swail to the port wall to load the back of the bearing. I have seen this before. Ill make a new spacer to take up the end play.
51696110911_b4c4a354d6_h.jpgUntitled by barnstormerbikes, on Flickr
I worked on the front brake a bit. I had already relined the shoes with aggressive material and when setting the brake up ran into a few problems. The wheel dish was way off so I faced off the KDX brake plate to help solve the problem.
51696111171_84d98684d4_h.jpgUntitled by barnstormerbikes, on Flickr
I used a longer alloy rear arm which has poor alignment with adjustment point so the housing stop will be part of the anchor arm (This one was not well designed with some misalignment at the rear hole)
51673702629_607aaa27be_h.jpgUntitled by barnstormerbikes, on Flickr
51696111071_2b3b03a87a_h.jpgUntitled by barnstormerbikes, on Flickr
51695318567_b7248e2b72_h.jpgUntitled by barnstormerbikes, on Flickr
51696789029_c04a3e9c9c_h.jpgUntitled by barnstormerbikes, on Flickr
I also made a front axle from 1045 steel with alu cap.
51668981459_cf425bf9fb_h.jpgUntitled by barnstormerbikes, on Flickr
51673898275_e57f55ae57_h.jpgUntitled by barnstormerbikes, on Flickr
Thanks for looking. I have some rim questions!
I have three front MX rims, two are for conical so the third can't be easily used.  They are all marked 1.6X21 but vary in outside width from 2.1" to 2.5" on the outside. with the narrowest one being 1.75" on the inside?    What is typical? Why?
51696998675_5bcc55ee8c_h.jpgUntitled by barnstormerbikes, on Flickr
Edited by Ftwelder
Shouldn’t the brake backing plate be on the left fork leg?
