Clutch lever feel
I have a 2022 125cc GP. The last trial I rode at the weekend. The clutch got very heavy to pull in. And then it would get light again, the clutch still worked OK either way. What would cause this or is it normal.
I don´t think normal and it happened in a short period last weekend. I would investigate the cause of friction and find a remedy.
That has so be frustrating on a brand new bike. Definitely not normal. Maybe the clutch drive/friction discs are catching on the clutch basket edges? Have you tried changing your transmission oil?
The transmission oil is changed every couple of hours. It is frustrating it was working fine until last week.
Check the basics first; How tight is the bolt which snugs the lever to the housing at the pivot point? Is something restricting that movement? Check the fluid level in the master cylinder.
Thanks for all the help. I found it, the edge of the O ring had broke off and got stuck in behind one of the paddles. I will give it a good try tomorrow.
