November 8, 20224 yr Hi, I have a 2013 Scorpa sr 280! Starts no problem & idles fine, but when you give it throttle it bogs out and has intermittent revs. New cdi, stators been checked and it’s fine, carbs checked and clean, new air filter, piston / rings all good. Am at a serious loss as to what’s going on!! Any help most appreciated.
November 9, 20224 yr Main bearings and seals and check the exhaust. The 2013 has the rear mounted tank? Fuel pump/vacuum issue.
November 9, 20224 yr Author Hi! It’s a front mounted tank! Main bearings and seals all good. Bikes been checked over by 2 different garages and they can’t see any issues with anything!! I have been told to try an iridium spark plug an shorten the gap by .5mm, so waiting on that arriving🤞🤞🤞 if no I’m completely stumped!!
November 9, 20224 yr 14 hours ago, lineaway said: The 2013 has the rear mounted tank? Are you thinking of the Sherco? Anywho, in other news if an iridium plug fixes it then it must have a weak spark, so that's at least easier to dig into for an answer. I'm guessing you already did sanity checks for old rags left in the airbox or intake? (I've done that before, lol)
November 9, 20224 yr Author No ***** been left anywhere! And shouldn’t really be an issue wi the spark as the cdi/coil is new but last throw of the dice is try the iridium plug🤣🤣🤣 carbs all good!!
November 9, 20224 yr If it starts and idles fine, the stator and gap are likely ok. "Carb checked and clean" is where I'd back track. Have you confirmed the correct jet size, needle position? Off idle your looking at the air screw and needle clip position. Edited November 9, 20224 yr by UG_ALLSTAR
