Air leak at tire lock
DRM
9 hours ago, DRM said:
I have a 2022 GasGas TXT Racing 300 and I am leaking air from the wheel lock on my front tire. I loosened the lock, cleaned it and re-inflated and it still leaks. Any suggestions?
You can't be serious with a question like that, surely?
The front tyre is not tubeless like the rear (hence the tyre lock). There will be a puncture in the tube, so you need to remove the tube then repair/replace it taking care when reinstalling that you don't pinch it as you lever the tyre back onto the rim.
29 minutes ago, Intotrials said:
It seems the poster assumes that the front is tubeless like the rear.
Yes, It appears that way to me.
DRM, pump your front tyre to something like 20 psi now, check it again in 24 hours. Figure it out from there. Simple like me.
First time poster, we've probably been duped.
  • Like 2
