kasper Posted June 9, 2023 Report Share Posted June 9, 2023 Hello I have a 2014 GG Replica, it has an "older" rear brake master cylinder (part number BT660002811) as it wasn't available quickly enough, I bought the newer version (part number BT66000GG-CSV-1). The banjo on the older is 8mm and the more recent is 10mm, I made the new house with proper banjos. However, I am not able to get it working correctly. The brake is really weak, almost non-existent. There is a chance, that I still have air in the system, but pumping the brake does not make it any better. Checked/done so far: 1) No leaks; 2) New hose, proper armoured hydraulic hose, professionally made 3) Probably no air, I injected the oil from the calliper side, with a large syringe. Slowly pushed thru a few hundred millilitres; Link to comment Share on other sites More sharing options...
arnoux Posted June 9, 2023 Report Share Posted June 9, 2023 Just my take on bleeding Trials brakes (and we do a lot of them as I have a bike business) is that you are way better "pulling" the fluid through at the rear bleeder screw, than pushing it through like you are. If you have air behind the caliper pucks pushing fluid in does not clear that. The fluid takes the path of least resistance and goes from the bleeder straight to the reservoir. Much better having the reservoir cap off, fluid level full, and draw the fluid through the system, this then draws out any air bubbles deep in the calliper. I have always found this a much better way to bleed rear brakes. Couple of notes: always make sure you have a little freeplay on the actuating rod, so the piston comes all the way down. That makes a clear path from piston bore to reservoir. Try and use a vacuum bleeder for the best results, but a syringe works also, just not as efficiently. And don't worry about seeing bubbles in your tube from the bleeder. When doing this method you will always get some air draw from around the bleeder. Just pull a full reservoir of fluid through and that should be sufficient. 3 1 Link to comment Share on other sites More sharing options...
rotors7 Posted June 10, 2023 Report Share Posted June 10, 2023 Rightly or wrongly I always use ptfe tape around bike or car bleeder nipples to try to stop the 'false' bubbles. It usually does the trick for me when vacuum bleeding. 1 1 Link to comment Share on other sites More sharing options...
kasper Posted June 10, 2023 Author Report Share Posted June 10, 2023 Yesterday, after posting it here I read more about the bleeding of the rear brakes. I understand that the process is tedious. I will give it another try, unfortunately, I don’t have the vacuum bleeder, but I’ll give it a try with syringes once more. @arnoux made a valid point that the back of the pistons might still have air bubbles trapped in them. Regarding my original question… The master cylinder should be interchangeable as the rear callipers are the same on both master cylinders. So there should be no difference in the length of the stroke or the volume of the brake fluid. With the older master cylinder, there is a chance to open the top lid without unbolting the master cylinder itself from the frame. With the new one, there is no chance to do it. Also, for future users/others, the brake hose banjo on the cylinder side is 10mm instead of 8mm. It is no 1-2-1 swap. And thank you both @rotors7 @arnoux 1 Link to comment Share on other sites More sharing options...
kasper Posted June 10, 2023 Author Report Share Posted June 10, 2023 It was air, as I don't have a vacuum pump, here are the steps I took, which might be useful for someone else as well: 1) Check the calliper on the bike and ensure it is adequately filled. In my case, it was already almost full. 2) Remove the bleeding screw. 3) Take off the hose banjo bolt. It's a good idea to have two new copper washers (10mm) ready. 4) Find a thin and soft wire and use it to stir and disturb the screw holes as much as possible. You can also tap the calliper gently. This will help the air escape from the piston and other cavities. Make sure that the oil level is clearly visible from the banjo bolt hole the whole time. 5) Put everything back together. 6) Next, use a syringe to slowly backfill the entire system from the bleeding screw. The goal is to push the air into the master cylinder, so take your time and do it as slowly as possible. 1 Link to comment Share on other sites More sharing options...
Snipes Posted August 8 Report Share Posted August 8 1. you said check the caliper? did you mean the master cylinder? 3. hose banjo bolt from the master cylinder? I'm trying to bleed my rear brakes on 2017 txt 250 and am frustrated. I tried rebuilding master cylinder. vacuum bleeder on caliper bleeder but doesnt draw any fluid. back bleeding , fluid wont go into bleeder screw, feels like I try to push fluid in but it wont go. next I'm going to try rebuild the caliper. any ideas? thanks! Link to comment Share on other sites More sharing options...
Tr1AL Posted August 8 Report Share Posted August 8 8 hours ago, Snipes said: 1. you said check the caliper? did you mean the master cylinder? 3. hose banjo bolt from the master cylinder? I'm trying to bleed my rear brakes on 2017 txt 250 and am frustrated. I tried rebuilding master cylinder. vacuum bleeder on caliper bleeder but doesnt draw any fluid. back bleeding , fluid wont go into bleeder screw, feels like I try to push fluid in but it wont go. next I'm going to try rebuild the caliper. any ideas? thanks! As I cannot see what you are doing I may be wrong but as you describe the problem being that fluid will not push or pull through the system it would seem that the piston in the master cylinder is not against the clip that retains it in the bore and as such is blocking the fluids return to the reservoir. Regards Alan. Link to comment Share on other sites More sharing options...
lineaway Posted August 8 Report Share Posted August 8 (edited) Remove the rear brake pedal comepletely. Use a phillips screw driver to pump it. You are far better off with a clear tube over the rear fender. The air will not move until the fluid is above the master cylinder about 8 inches. Edited August 8 by lineaway Link to comment Share on other sites More sharing options...
Snipesleft Posted August 9 Report Share Posted August 9 7 hours ago, lineaway said: Remove the rear brake pedal comepletely. Use a phillips screw driver to pump it. You are far better off with a clear tube over the rear fender. The air will not move until the fluid is above the master cylinder about 8 inches. 15 hours ago, Tr1AL said: As I cannot see what you are doing I may be wrong but as you describe the problem being that fluid will not push or pull through the system it would seem that the piston in the master cylinder is not against the clip that retains it in the bore and as such is blocking the fluids return to the reservoir. Regards Alan. I replaced the inside of master cylinder with a new rebuild kit. came with a new spring, I don't know what it's called but the long metal cylinder thing that pushes in and out and finally the circlip, then the rubber boot. everything in there works fine. so when you say better off with clear tube over fender, is it just a long hose connected to the bleeder screw? Link to comment Share on other sites More sharing options...
lineaway Posted August 9 Report Share Posted August 9 Yes, let gravity do the work! Link to comment Share on other sites More sharing options...
Please sign in to comment
Sign In Now
