andrenld Posted January 4, 2024 Share Posted January 4, 2024 (edited) andrenld Posted just now Hello.guys I am currently looking for new parts for my gasgas jt25 contact 1995. I am looking for al the bearings in the swing arm and rear shock. Crankshaft bearings Al the seals in the engine and cilinder. Also looking for a lot of new parts to restore the whole bike. Do you guys have any idea where i can find those parts? Thanks for helping me Andre Netherlands Edited January 4, 2024 by andrenld Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 4, 2024 Share Posted January 4, 2024 Most /all the bearings can be bought from a bearing supplier. The number is generally on the individual bearing. Crank bearings are normally c3 clearance. 1 Quote Link to comment Share on other sites More sharing options...
marky dee Posted January 4, 2024 Share Posted January 4, 2024 May be Zone Trial...??? Quote Link to comment Share on other sites More sharing options...
andrenld Posted January 4, 2024 Author Share Posted January 4, 2024 38 minutes ago, b40rt said: Most /all the bearings can be bought from a bearing supplier. The number is generally on the individual bearing. Crank bearings are normally c3 clearance. Thanks for the information. I will look into this. All the swing arm bearings and seals that i am looking for. Do you know anyone where i can order these. I have search al over the internet but only can find a set for the 98 model Thanks Quote Link to comment Share on other sites More sharing options...
andrenld Posted January 4, 2024 Author Share Posted January 4, 2024 Great i will see there Quote Link to comment Share on other sites More sharing options...
faussy Posted January 4, 2024 Share Posted January 4, 2024 (edited) Have a look here https://www.thehellteam.com/technical-support/gas-gas-parts-and-service-manuals in the parts list section. Usually they have the bearing number in the name of the piece Edit: i had a quick look, looks like hk2020 and 20-26-4 for the main swingarm, and 6206 c3 fort he main bearings. I would not buy cheap branded main bearings though, always use a reputable brand like skf or fag. For the bushes, you will either have to try and buy them or get them made. Edited January 4, 2024 by faussy 1 1 Quote Link to comment Share on other sites More sharing options...
Tr1AL Posted January 4, 2024 Share Posted January 4, 2024 6 hours ago, andrenld said: Great i will see there Rear Shock rose joint/ spherical bearing in the shock eyes of a GasGas JT model is normally a GE12PW size ID = 12mm OD = 26mm W = 16mm . 1 Quote Link to comment Share on other sites More sharing options...
