Who has tried a soft clutch support ring?
F5Dave
20250928_130839.thumb.jpg.594bbdfd459905e10d790e7350cbeeea.jpgAs title.  You can supposedly get a H, M, Or S support ring..
This  apparently gives a softer, well if you choose S over M which is standard.
I also put GRO Rockoil 75 in.
There's f all difference in the support rings.
But, well maybe I can tell the difference.
I've only ridden up the driveway a few times and then in circles for a few minutes.  Actually it does feel easier.  My GG250 did seem more progressive  .
After a horrendous medical event I have been left clumsy and unbalanced. My GG would have been easier to come with..Jebuz,  I'm lucky to be walking.  But 2 years on if can ride my trials bike.
But I am bouncing off stuff.
Hence the softer ring.
So more updates when I actually get to ride off road properly.
Edited by F5Dave
The different "support rings" available from TRS (Soft , Medium and Hard) just change the amount of pre-load on the Belville Spring. Much like your pre load rings on your rear shock.
But the Belville is still the stock 1.5mm thick spring.
The Soft ring will reduce the pre-load, but it is not the only answer.
The thickness of your five combined clutch plates affects this as well. So if your plates have swollen (this happens with some oils and over time) then there is more pre load on the spring. Conversely if the plates are under size compared to standard there is less pre-load on the spring. So this is why combined plate stack height is so important.
These diapraghm clutches are fantastic because they can be tuned to suit the riders requirements, but you need to know exactly what you are doing, and it is extremelly fine measurements you are dealing with.
If you have hand problems and really want that super easy light clutch, that does come with some compromises of course as the bite, or take up point, is also softer and less precise, then you can use a thinner Bellville Spring, but some other changes need to be made as well or you get bad slip.
Here is a link to a kit with the super light spring and the other parts that compensate for that to give the lightest clutch possible. But first check your 5 plate thickness and make sure that has not crept towards or over 10mm.
https://www.thehellteam.com/trrs-soft-clutch-kit
Hi, thanks for the detailed response.
Yes I had seen that kit but figured i hadn't even changed the oil yet (I was off riding for a couple of years or at least Trials which is hard when your balance and coordination take a king hit.
Actually I have to ride two finger clutch,  well 1 &2/3 as i lost a tip. I mean I didn't lose it, I know where it ended up, hospital incinerator.
But I find the '23 lever light enough.
My issue is my body vs head is not as sharp as it once was. I'd asked my dealer what oil the guys use and he did mention he had a soft ring in stock so I thought it was a good 1st step.
On my Beta I did the usual take sharp edges off plates they seem to suffer and machined so top hats to reduce the preload. Transformation.
I've machined baskets etc on road and race bikes usually to add another plate when power has been increased (like my 500 kitted RZ350).
But diaphragm are new to me. I guess that's kit is my next step if I'm still a loose cannon when I'm fit enough to do another Trial.
Thanks.
You might slow it down. It's awful fast with the stock gearing. Using a 9 tooth is the fastest choice. I prefer something in the middle. A 42 rear. I like a 9 and 38 actually.
