Fantic 200.. What A Bike!
14 replies to this topic
#1 stefan
    New Member
  • Members
  • Pip
  • 20 posts
  • Bike:Montesa Fantic
Posted 05 December 2006 - 08:53 PM
Hi there,
finally after a year of searching I got myself a 200 and can put my TLR200 to rest. I am really impressed by that wee Fantic! What a nice handling bike and the power picking up sooo smooth... you know what I mean!
Only a couple a things I probably want to fix:
-Clutch needs a lot of finger-force: cable is mooving freely.. anything else to have the clutch actuation less "blistering" (to my finger, that is..)
- Clutch slip in 5th/6th gear... No noticeable slip in lower gears... what oil do you recommend?
Cheers!
#2 fantic156
    Member
  • Members
  • PipPip
  • 89 posts
  • Bike:Mont, Fantic, Beta
Posted 05 December 2006 - 09:07 PM
Put some new clutch plates in, I got mine from Steve Goode, I had a new kickistart as well as mine was a bit worn and then take out two of the clutch springs from opp sides of the basket so the plates seperate evenly and the clutch will be much lighter. Works fine been doing it for years (since the bike was new). Loads of people used ATF in the 80s I never did can't remember what I did use then, but use ELF HTX 740 in all the bikes now. It's expensive but works like no other IMHO (no drag or sticking even when cold). Enjoy. :guinness:
#3 bilco
    Advanced Member
  • Members
  • PipPipPip
  • 612 posts
  • Bike:fantic 200
Posted 05 December 2006 - 09:40 PM
Nice choice stefan enjoy the old girl :moon: :guinness:
IT TAKE'S ONE MAN TO SEND A NATION TO WAR.
IT TAKE'S A NATION TO END WAR.
#4 Lee Harris
    Advanced Member
  • Members
  • PipPipPip
  • 1,104 posts
  • Bike:Fantics
Posted 05 December 2006 - 10:45 PM
I run atf also, but if your clutch slips, think about new plates. Steve boy goode is good if yer know what I mean?
Is the tlr a reflex or a puka trials bike? Up for a swap?
lee
I swear to drunk I'm not God!"
#5 HapOswald
    New Member
  • Members
  • Pip
  • 21 posts
  • Bike:RSC TL220R
  • Club:sacto pits
Posted 05 December 2006 - 10:59 PM
I use Dexron III atf in almost everything(2 cycle) cheap and change often......interested in the TLR200 also...
#6 FANTIC*ROB
    New Member
  • Members
  • Pip
  • 22 posts
  • Bike:FANTIC 240 & BSA B40
  • Club:Northallerton
Posted 06 December 2006 - 02:52 AM
TREAT YOURSELF TO A HEBO HYDRAULIC CLUTCH KIT . I PUT ONE ON MY TRICK 200cc 200 FANTIC AND NEVER LOOKED BACK . I ALSO USED ATF IN HER AS I DO WITH ALL MY FANTICS 240'S RIGHT UP TO SECTIONS AND THE CLUTCH'S HAVE ALWAYS BEEN FINE . NO STICKING WHEN COLD .
#7 stefan
    New Member
  • Members
  • Pip
  • 20 posts
Posted 06 December 2006 - 03:15 AM
Hey prospective TLR buyers.. you realize that the bike is in New Zealand... don't you?
Will have a go at the clutch once I stop having the urge to play.. might be a while!
#8 Ridgrunr
    Advanced Member
  • Members
  • PipPipPip
  • 217 posts
  • Bike:2008 Scorpa SY250R
  • Club:Utah's Wasatch Trials Association
Posted 06 December 2006 - 06:21 PM
For that cable clutch, you can get a leverage enhancer. They are called an Easy Clutch. I put one on my 92 Fantic 307 and my 74 Yamaha TY250 and it made a huge difference. One finger clutch afterwards.
They just go between the throttle and the cable, look like this:
http://www.adarmx.co.uk/online_shop/index....target=d86.html
#9 wilsyfm403
    New Member
  • Members
  • Pip
  • 7 posts
Posted 07 December 2006 - 07:51 PM
Have you seen the mods for fantic clutches on Trials central? I have modded my 300 and a friends 200 with it and it works a treat look at the actuator arm on the back of the engine this needs to be extended about 20mm then fabricate a new cable mount from steel/ally, that bolts onto the old mount but takes the clutch cable across 20mm and down about 10 mm. I made mine from ally and incorperated a cable adjuster into it.
The engine needs to come out to do it really. There are pics of the mod by others on here some where!!
Good luck where about are you in the land of the long white cloud?
#10 FANTIC*ROB
    New Member
  • Members
  • Pip
  • 22 posts
Posted 08 December 2006 - 10:06 AM
this mod only works on the forward kicking engines . The minarelli engines is a totally differant affair .Hydraulic is the only way to go in my eyes
#11 Lee Harris
    Advanced Member
  • Members
  • PipPipPip
  • 1,104 posts
  • Bike:Fantics
Posted 08 December 2006 - 06:04 PM
actually the minarellis can be moded in the same way. add a chain link, (one side) fixed with a 3mm nut and bolt. Put one on the clutch actuation arm that goes under the flywheel cover. A really slick action comes if you raise the cable fixing on the top of the motor also. If you use a 428 link, I think that is best. If you use a 520 link the clutch is even lighter but for me too long!
lee
Edited by Lee Harris, 08 December 2006 - 06:49 PM.
#12 FANTIC*ROB
    New Member
  • Members
  • Pip
  • 22 posts
Posted 08 December 2006 - 10:19 PM
I tried that no were near as good as hydraulic !!!!!! i started a trend in our center most people now have hebo kits fitted to there 200's and even 240's but i dont think 240's need them , the extention arm is enough
#13 bilco
    Advanced Member
  • Members
  • PipPipPip
  • 612 posts
  • Bike:fantic 200
Posted 08 December 2006 - 10:37 PM
do you have a picture to how you connected it up to the clutch arm on the engine.
thanks
#14 Lee Harris
    Advanced Member
  • Members
  • PipPipPip
  • 1,104 posts
  • Bike:Fantics
Posted 09 December 2006 - 10:55 AM
......but is a hydraulic clutch " in the spirit of twinshock trials"? Or do you just ride for fun.......
i think we´ve been here before!!!
#15 Grib
    Advanced Member
  • Members
  • PipPipPip
  • 242 posts
  • Bike:Fantic 240
Posted 10 December 2006 - 09:57 PM
I'm not sure about classic trials in general but the Manx classic regs do not allow hydraulic controls.
