Removing Rear Wheel Bearings
10 replies to this topic
#1 High_Fiver
    New Member
  • Members
  • Pip
  • 15 posts
  • Bike:2006 Gas Gas pro 250
Posted 31 May 2010 - 07:42 PM
I have a bit of play in the rear wheel so new bearings ordered,the question is how difficult is the bearing removal?
does it involve a lot of fist shaking and quality swearing or are there any tips for making it a painless process
as you can gather i havent done this before so any help would be great
thanks in advance
#2 proc
    Advanced Member
  • Members
  • PipPipPip
  • 180 posts
  • Bike:sherco
  • Club:Lancs County mcc
Posted 31 May 2010 - 08:00 PM
boil the kettle then pour it on the hub it makes it expand making it easier to drive bearing out with a long drift or screwdriver :rolleyes:
#3 shercoman2k8
    Advanced Member
  • Members
  • PipPipPip
  • 601 posts
  • Bike:09 Paxau Sherco 125
  • Club:L&DMCC
Posted 31 May 2010 - 08:02 PM
I find getting a raw bolt from your local hardware store is a major help. Never mind trying to tap them out evenly with a drift and hammer, just place the rawbolt inside the wheel, tighten it up so it expands widthways, make sure it is very tight and tap with a hammer. Should knock them out nice and clean. Soak around the bearing with penetrating fluid for easier removal. Quick job if you can pick the knack up :rolleyes:
#4 Pete_Scorpa3
    Advanced Member
  • Site Supporter
  • 1,440 posts
  • Bike:Scorpa SY250
  • Club:Stratford-Upon-Avon MC&LCC
Posted 31 May 2010 - 08:12 PM
View Postshercoman2k8, on May 31 2010, 09:02 PM, said:
I find getting a raw bolt from your local hardware store is a major help. Never mind trying to tap them out evenly with a drift and hammer, just place the rawbolt inside the wheel, tighten it up so it expands widthways, make sure it is very tight and tap with a hammer. Should knock them out nice and clean. Soak around the bearing with penetrating fluid for easier removal. Quick job if you can pick the knack up :o
I recently read that very good tip on another thread, I'd never thought of that before! :rolleyes: Still waiting to try it for myself.
I've always welded on an old nut or bolt and tapped that out, but then I've got a welder permanently set up in the garage, so it's an easy option.
Will try the rawlbolt next time.
Pete
#5 ratman
    Member
  • Members
  • PipPip
  • 42 posts
  • Bike:beta
Posted 31 May 2010 - 09:17 PM
Hi, rawlbolt everytime, as before, go steady works a treat .
#6 steve1979
    Advanced Member
  • Members
  • PipPipPip
  • 195 posts
  • Bike:GG 03 txt pro 250
Posted 01 June 2010 - 08:23 PM
When you get the new bearings pick the seals off the sides and pack more grease in, there's never enough in there from new, and if you can wait put the new bearings in a plastic bag and put them in the deep freeze overnight and they will shrink slightly making putting them in alot easier do this as well as the boiling water over the hub as previously mentioned and they will go in a treat
The Shetland Stig
#7 JSE
    Advanced Member
  • Members
  • PipPipPip
  • 2,025 posts
  • Bike:Gas-Gas Pro, TY350s
  • Club:NEOTT-Life member, Texhoma Trials Club, AMA-Life Member
Posted 07 February 2011 - 09:52 PM
The bearing and hub quickly normalize in temp as the hub temp drops and the bearing temp rises so it's usually not ever a problem (and the temp differential is small). If you use a big socket that just fits inside the hub and attach a long extention to it you can tap the bearing in easily. The long extention makes it simple to keep the bearing straight when driving it in.
Jon
#8 RichT
    Advanced Member
  • Members
  • PipPipPip
  • 208 posts
  • Bike:All Been Stolen
  • Club:Macc & Manchester17,
Posted 08 February 2011 - 11:01 AM
Should'nt be neccessary they only need to be 1/3 packed,
Why? Too much grease can cause the balls to skid and not roll on the raceways and wear flats on them. If the extra grease is not the same, Mixing greases is bad practice as it can lose its properties like set like a wax or turn fluid.
Before now for my Enduro bike I have tried removing the grease by soaking in a solvent and replaced it for a water proof grease but it is not worth messing.
Edited by RichT, 08 February 2011 - 11:02 AM.
#9 steve1979
    Advanced Member
  • Members
  • PipPipPip
  • 195 posts
Posted 08 February 2011 - 09:19 PM
Thats a fair comment Rich :) i just like to get some good qaulity silicone grease in there.
The Shetland Stig
#10 legionnair
    Member
  • Members
  • PipPip
  • 75 posts
  • Bike:2008 gas gas txt pro
Posted 09 February 2011 - 02:40 AM
An added insurance is put alittle never seize on the out bearing surface before putting it in and this will make removal easier next time. I also pack in between the bearings with grease to keep water out of the hub
Good luck
Dustin
#11 2/4
    Advanced Member
  • Members
  • PipPipPip
  • 639 posts
Posted 09 February 2011 - 12:21 PM
I agree with not overpacking but the amount of grease in some bearings is pathetic and is bound not to be of a waterproof variety. Remember the coating that is all you get in most will soon be washed away, seals or no, so get a reasonable amount of good waterproof grease in. Picks available currently at Aldi for about 3 quid to ease the job.
