This stream auto-updates
  1. Yesterday
  2. Is a bicycle helmet as safe as a motorcycle helmet? Probably not. But modern MIPS-rated helmets are pretty good. See: https://www.helmet.beam.vt.edu/bicycle-helmet-ratings.html It may partly depend on the ambient temperate at which you ride. I know that if my brain gets overheated I don't make good decisions, and am more likely to actually need a helmet. Assumption of personal risk is a very personal decision.
  3. I’m not sure I agree with an MTB helmet so I’m putting this out there for consideration. There’s an old saying that goes like this, “Buy the best helmet you can afford!”. The reason being is that you’re playing Russian roulette with your brain. MTB helmets aren’t subject to the same testing standards as DOT helmets are. Yes, trials riding isn’t as fast as street or MX but what happens if you go down and the bike lands on your head that’s next to a tree, rock or hard pack. The shells on MTB helmets aren’t as strong as a rated helmet because MTB bikes weigh a fraction of what a motorcycle weighs.
  4. Back with learndings about the electrical system on my EVO after it glitched and cracked some ribs. Thought it was carb but seems it was electric. One interesting insight was how the electrical system finds ground for the spark plug. The other was the revelation that the 300 Ohms called out in the owners manual for the trigger coil might be a wrong value so if you're diagnosing your Stator and the trigger reads 185 Ohms you're probably OK. EDIT, fixed some typos Beta debug.pdf
  5. Probably the best-ventilated helmets are for mountain biking (MTB). Might be worth a look if your club does not require a motorcycle-specific helmet. Probably easier to find a vendor to try something on as well. My wife wears a full-face MTB helmet all season for trials.
  6. I agree with you Konrad, I need to try it on before buying, the problem I have here in Quebec, is there is not a lot off trials gear retailer and they are quite far apart, so any info will probably save me a lot of traveling.
  7. If there is any way for you to try on a prospective helmet before buying, I strongly suggest you do so. I bought a GasGas-branded Hebo Z4 Carbotech by mail because it was a fabulous price. The Carbotech is a top-of-the-line helmet with two annoying (to me) "features". 1. The cheek pads were far too tight, despite the helmet otherwise fitting perfectly. I figured they would eventually "pack out", but did not. I ended up removing them completely. 2. The buckle hit my Adam's apple, which was most uncomfortable. I eventually improved that somewhat, but it's far from perfect.
  8. Flash1
    It's for sale if anyone's interested
  1. Load more activity
