37 -
many thanks for that.has been left in a box for now as i decided to buy a mar to rebuild for my sins in a previous life
Is on a 330 montesa. Is running a bit rich
I am trying to compare the needle in the carb to replacements. The marking on the needle is NAPH. Would anyone know what size this is, as the new needles have different codes and there does not appear to be a cross over chart. Many thanks.
Hi steve, I have come across this myself. I believe there is a small top hat that goes either side of the bearing that sits inside the rear shock bottom mount. With regards the loom i did away with the loom and run just the red to the coil as I have no lighting kit. I believe the pink is for the rear brake pedal switch.
what parts you after
Here is my 330, cold do with a clean
Is the star shaped wheel in the picture in the neutral position?
The rear shocks look odd from the back and dont appear to mirror each other in their angles and just to check is all correct. Same with the clutch parts as the spider and push pin come in multiple sizes depending on which engine they come from.
i am trying to find information about the above bikes.The 330, I would like to know the internal dimension of the swingarm at the rear spindle (with spacer sizes). Also the front spacer sizes. The 335 i would like to know the height of the clutch actuator or spider and the depth of the brass pushpad. Any help would be appreciated.
Hello Alberto, Steve said thanks for the kind words, and that the cash is in the post
Anyone have any knowledge of what this part is and where i can get one. It does not show up as an individual part number in the montesa parts manual, and is next to the rebound spring on the seat pipe in the left hand fork. Not sure if its a bump rubber or a seal as the old one is unsalvageable.
Recently acquired a 330 cota and was wondering if anyone has any info regarding clutch mods. Also manual recommends sae 90 for clutch, is this better than gp10? also primary drive recommends 300ml of oil, yet 335 engine recommends 450ml
Have a beta rev 80 in need of a rear shock, does anyone know of another shock that will fit. I believe it is 240mm center to center.
Saw this hidden behind a van at the weekend, thought they did not make them anymore.
