ATF is fine, I've used it in various bikes for years. On my sons bike I changed to Putoline Nano Trans to try and make the clutch more progressive but now it sticks when cold, Never had a sticking problem with ATF but it does make the clutch a bit sharper.
Plug wise I prefer a bp6es, It runs a bit cleaner in winter if you use low revs alot, Bp7es is better in hotter climates and summer it will help if it pinks, Ive always used 0.7 to 0.8mm gap.
If they are leather use normal black shoe polish, They won't soften much but will help keep them waterproof and stop them cracking. Get lots into the stitching and seams.
If they are synthetic then use a waterproof spray like scotchguard.
The top guys can ride in all conditions but over the last couple of years all they do is show off playing the my bikes a unicycle trick, It's just a fashon.
I found the same problem when putting an S3 head on a Sherco, The bolts are a smidge too long, A quick trip to the bench grinder and take 1mm ish off done the trick.
If it's a manual 50 (cadet or rookie), I can see a weight being a benefit as it's an adapted engine from a road going bike (Morini) and has a light flywheel.
I presumed the bike in question was a TXT boy but forgot they did the manual bigger 50 for a couple of years also.
Pull the flywheel cover off and check it's not mud rubbing on the inside cover, while you are there take out the plug and rotate the engine by hand using the flywheel to see how the mains feel, also check for up and down play by hand on the flywheel.
The mains will have a minute bit of play even when new as the bearing has to be able to expand with heat.
It could be something else but without hearing the bike, can only point to the usual suspects.
That setup should work, It will be on the rich side but will help with detonation.
I have just set up a 14 factory with a 48 pilot, 128 main and the std 4 slide with a jjh needle clip in middle, Its had some ignition and compression mods and it runs very smooth with no detonation, A tad rich off the bottom but it's being ridden by a novice so it will stay that way till he improves.
You could go to a 45 pilot with the 4 slide and change to a jfh neddle, This is more cost effective than buying a slide.
If you want an aggressive setup 3.5 slide JJH needle, 125 main and a 45 to 48 pilot, Needle 2nd from bottom.
With a 48 pilot the air screw will be 1.5 to 2 turns.
What symptoms are you getting? If it's a new Sherco I would imagine it has an air leak as the stupid plastic manifold is a piece of junk, Sherco are aware of it and just supply a foam gasket to help it seal.
You will have to order a box of manifolds at 50 quid each to find an almost good one!
Speak nicely to Chris at splatshop and he will try to find you the straightest one possible.
Check your float level and while you are there check what jets it's running.
Also give the carb a good clean, As it's new it doesn't mean its clean as the carb was probably pulled from a box and just chucked straight on the assembly line.
The Beta's are shipped with a rich pilot, (52 I think from memory) a 48 or even a 45 does clean them up off the bottom, But that's a last resort as it should run o.k and work as intended from new. Jetting is personal preference.
If after checking the float height and cleaning it does not solve it, Take it back to the dealer and ask them to pdi it properly.
Dadoff could be spot on here, I stripped mine during the week as I had some movement and noticed the bearing outer race had quite a bit of movement in the frame.
I had 2 sets of new bearings in stock and tried both but still had movement. There are 2 tricks among others to sort this in alloy frames.
The 1st one is with a sharp center punch and make punch marks on the inner frame where the bearing fits. The protruded marks from punching will reduce the diameter in the places and the bearing will tap in snug.
The second and I would only recommend this in very extreme cases is wrap quite a few layers of tape around the outside to avoid marking the frame then tap the frame to make some tight spots in a sort of octagonal shape but only very slight as it's only a microscopic amount of play to remove. This is an animal approach but it worked on an old rev 3 and lasted my abuse.
I also had play in the top yoke on mine where it meets the steering stem, The centre punch trick worked spot on too.
I think Italian engineering had a lapse when it came to these parts, especialy the factory yokes. If my bike was new I would be screaming warranty by now.
I can't vouch for the 125 but the carbon reeds do give more torque and quicker revs in the 300's.
A high compression insert will give it more grunt off the bottom and make it it more snappy at low revs.
I have a head insert for a 125 sherco, I think its a high or very high, I'll have to double check, I got it used as a complete head but only wanted the outer part, You can have it if you want it, It's just gathering dust on the shelf.
Sherco parts are slightly cheaper than Gas Gas and A shed load cheaper than Beta.
Beta's are cheaper bikes when new but wear and tear parts like swingarm bushes and linkage bushes are insane, Beta are the best for warranty and dealer back up, So it's get what you pay for.
The cost of keeping an 07 Sherco going will be cheaper than a Beta. Plus the year of Sherco's you are looking at are fairly bomb proof.
Silicone does work most of the time, Or this is a handy tool to expand it and good for reachable dents. I don't think people normally spend that much on rev 3's anymore so you might find only a few have the s3 pipes.
Rain and winter is not fun, I don't mind mud but cold and wet sucks.
The worst thing is dark evenings. By the time the last rider has finished, Flags picked up, Control packed up, Wait for burger van to pack up and push it out the venue.
Then get home and find it's too dark to wash bikes so have to knock off early Monday to do it.
And all that is after spending the day before getting wet and cold putting flags in the ground!!
All that aside I would not change it, I take the rough with the smooth as when the weather is kind it more than makes up for it.
The lot that can turn up 10 mins before, sign on, whine about the sections, finish by 3 and be indoors with a beer soon after have it good even in the winter!
Not much to the water pump on these bikes, The parts and seals are expensive If I remember right.
I've never seen a flywheel weight on one but if it's the 05 on engine they have a bigger flywheel anyway, If it's the earlier one you will be hard pushed to fit a weight to the tiny internal rotor.
It's an auto so I wouldn't worry about stalling LOL.
The standard 260 has brilliant quality suspension, Just as good as the Showa (unless youv'e got Bou's Showa). For a clubman rider it will do it all for you, It just floats over everything and is a joy to ride.
I love having a blast on Montesa's but they are not for me when it comes to the bigger, tricky or muddy stuff.
It would cost me a fortune to have one in the spec I want and I can't justify it when a 2 stroke at quarter of the price can do so much more.
Beta Rev 200 2004 A Few Questions.
in Beta
