Ive just removed and checked all clutch plates and mecanism and bearing cant feel any play or carnt see anything worn even gearbox bearings feel ok which they should be as there are new?
Right ive decided to change my gearbox oil tomorrow so i might as well remove clutch cover and check all clutch mecanism and plates. whats the best way to clean cutch plates?
Ive just removed and cleaned my techno 97 carb how do i go about setting the float level. i would like to check before refiting carb any help would be great?
I rebuilt my 97 techno engine and it was not cheap piston and rings were 90 quid and cylinder replate was a futher 100 quid and then you have conrod kit +all bearings and seals+oil?nearly 500 quid of a job.
i have noise on my 97 techno the noise seems 2 go quite when clutch is pressed. just recently rebuilt engine and gearbox with new bearings and conrod kit + new piston and cyl replate. the noise is on clutch side? as any one else had this problem?
My brother has just had his frame welded by john lampkins.he noticed that it was leaking fuel and on futher inspection there was a crack found in weld under fuel neck plastic trim on right hand side of tank has any one else had this problem? bike is a 2005 rev3
what gear oil is best ive been using pj1 but it does not seem to last long. before i have to change it because gears go very dificult to select on my 97 techno. ive just rebuilt engine with all new bearings and seals, piston and cyl replate and conrod kit?
Same problem as you mate need a service manual for my 97 techno. give us a shout if you find one i live in the same neck of the woods as you silsden? no look off lampkins.
Noisey Techno Clutch?
in Beta
