rotors7
    124
Posts posted by rotors7
  1. I remember going to a trials school hosted by Bernie Schreiber.
    A chap in his late 30's attempted a step on his ageing 250 Swm and failed miserably, kicking it in the process.
    Schreiber picked the bike up and proceeded to do everything he'd already done on his factory Yamaha, then casually handed the bike back to the awe struck bloke.
    There's just no substitute for skill and Schreiber was certainly not 5'7". :)
    • Like 1
  2.
    VERTIGO COMBAT VERTICAL 2018 DEVELOPMENTS
    - NEW CRANKCASE DESIGN TO IMPROVE THE SEALING OF THE CASES
    - INJECTED CLUTCH AND IGNITION COVER TO REDUCE THE WEIGHT
    - NEW ECU BY GET TO OPTIMISE START UP PROCEDURE
    - OPTIMISED GEOMETRY OF THE KICK START PEDAL TO HELP STARTING PROCESS ??
    - NEW SIMPLIFIED MAIN ELECTRICAL HARNESS
    - PROGRESSIVE LINEAL ROCKER SYSTEM WITH OPTIMISED REIGER DAMPER ADJUSTMENT
    - NEW SEAT POST AND REAR MUDGUARD
    - NEW AIR FILTER BY TWIN AIR
    - NEW AIR FILTER COVER
    - NEW RADIATOR GRILL TO IMPROVE AIRFLOW
    - GREEN HANDLEBAR PROTECTOR
    - RENTHAL GRIPS
    - REINFORCED SIDE STAND
    - NEW DECORATION COMBINING THE VERTIGO CORPORATE GREEN
    Maybe that's been sussed out already ?
  3. I bought a brand new 349 once on the first day of two weeks leave, within an hour of practice the hub shattered.
    The local trials shop laced a new one up the week after but all the spokes came out of the rim at the wrong angle.
    Another week went by and Sandifords put it right.
    A whole two weeks of freedom with no trialling, it was depressing :(
    So on that note if you'd like to send it to me I would love to vent my anger out on it with a sledge hammer !
    • Like 2
  4. Mike Hann of Bishops Caundle used to do a Fantic  '200 special', a 200 motor squeezed into a 125 frame. I seem to remember it was very competitive in the day. Just a thought.
    "Lovely little motor."
  5. It sounds like it could be the 'top hat' washers that go through the disk are worn.
    Really really badly worn wheel bearings..
    Or it could be your steering head bearings, but then the front wheel wouldn't move slightly.
  6. You ought to go back through and read "why don't they just grip".
    I've always thought they were the miracle cure to finding that elusive grippy line but after reading that thread I'm glad I didn't get one.
    It's hard enough trying to stay clean without having to change an already dodgy riding style !!!
    • Like 2
  7. On 7/28/2017 at 7:36 PM, drca said:
    Mostly curious...I was wondering if anyone know anything about the thread on the spokes and wheel nuts on a tubeless flanged wheel?  I know the threads are rolled instead of cut (easier / cheaper / more robust) but thread standard metric size, imperial or some special secret type used only for spokes?
    Thanks.
    I've just had a check on this and they are M4 X 0.7 :)
    • Like 1
  8. Do the bearings actually turn freely with no lumpiness if you put your finger in where the spindle goes and turn ?
    If not then the bearings are rotating around the spindle.
    Could also be seized piston(s) in the caliper or no free play in the brake pedal.
  9. I'm hoping we get an answer on this, I'm still gunning for a failed crank seal, it'll easily cause intermittent issues.
    I've had several sheared woodruff keys with 247 and 349 Mont's, they were totally knacked and wouldn't even start.
    If it was the rings then surely it would be smoking all the time ?
    Anyone taking bets ! :)
  10. I recently found my old Mecatecno on ebay for sale, the seller wouldn't 100% confirm the engine number or I would've bought it back :(
    Anyways I tracked it down and it's been given a good restoration job, the new owner didn't know it was registered so I passed all the info on.
    It's funny how a bike can mean quite a bit to someone, memories etc, even after selling it on to buy a more up to date and easier machine to ride !
    I always fancied a 'Rolls Royce of trials bikes" :)
  11. I presume you've checked it's got the right grade of oil in there ?
    Too thick an oil will most definitely help to create stiction between the plates.
    As already stated already it'll take a while of riding and warming up before they release.
    At least you know the box is working okay :)
  12. 42 minutes ago, dr770 said:
    Thnks for the kick start fredback, may be it will be easier to start. The compression is huge when it's warm.
    The kick start shaft has a lobe that's hidden away from view, a mistake many make is to mount the kick start too far forward.
    This means that by the time you get it in the position for a push, the lobe is much closer to punching a hole through your engine casing !
    I did it on my first 349 and it made a helluva mess :(
    • Like 1
  13. 2 hours ago, pmk said:
    Guessing Poofs is some other meaning for non USA English, I can only imagine what I have posted now to create such humor.
    OK I googled Poofs, yes, no doubt you all had good laugh over that one.
    You've just got to love our differences :)
    Definitely a good chuckle !
  14. Well I'm glad it's running okay now, sounds like you needed a tad of patience.
    As has already been mentioned poofs out of the exhaust isn't too good, if there's some oily smoke it could hide a multitude of sins !
