konrad
    319
Posts posted by konrad
  1. 5 hours ago, jimmyl said:
    I must be missing the point but what is the issue.
    For me, it's mostly about consistency of use.  None of my other bikes auto-retract (or at least they did not do so for long).  Every other bike I've owned provided an easy means to defeat their auto-retract mechanism.
    P.S. I removed the inner spring thinking that might do the trick, but no luck.  Not sure what that inner spring is supposed to accomplish -- maybe just Honda's "belt and suspenders" approach?
  2. Jonny, thanks for the idea. The brackets are inexpensive:
    0536-NN4-600 Bracket, Side Stand for ED/3E  $18.63 USD
    50536-NN4-D10 Bracket, Side Stand for 2E/4E $12.46 USD
    I wonder what the difference is? 3ED is the competition version, right?
  3. Does anyone have a solution to this problem?  I could not find anything via searching here.  No defeat strategy appears obvious to me.
    I'm unwilling to pay Mitani's price, or to remove it completely.
    Has this been a "feature" since the bike's introduction?
    TIA.
  4. 1 hour ago, dirtydalesman said:
    I don't have a transmission breather tube unfortunately, so can't try that.
    Interesting.  Is the transmission not vented at all?  Maybe that's part of the problem?   When the air/oil in the transmission expands, that can't make life easy for the crank seal.
  5. I have no idea what a Dalesman is, but 25:1 seems like a lot of oil for any trials bike.
    It might take a while for the motor to clean itself out even with no gearbox oil being sucked in.
    You can test for a gearbox-side crank seal failure by replacing the transmission breather hose with several feet of clear plastic tubing and then submerging the free end in a jar of water. When you blip the throttle, a bad seal is indicated by bubbles in the jar, or water being sucked towards the transmission.
    It also might just be very, very rich.
  6. I stumbled across this because of another thread.  I'm guessing it's been too long for the OP to still care, but perhaps my response will help someone else.
    CDI = Capacitor Discharge Ignition.
    The factory wiring diagram is truly horrible, and you were smart to attempt to draw your own.  In regard to your .PDF drawing:
    1. That "run switch" configuration would be very unconventional (and I suspect it is incorrect -- especially because it would be required to "open" to kill).  Typically, one side of the ignition coil would be permanently connected to earth.
    2. Kill switches typically "close" to produce the kill function, and "open" for the run function.
    3. The wire you have marked "Lights?" is unlikely to power the lights.  There's no need to involve the CDI in that task.  It's possible this is were a conventional kill switch would be connected (but more investigation would be prudent).
    4. Lights typically are powered via the low-voltage winding on the stator that powers the fan.
  7. 10 minutes ago, oaktrials said:
    just to clarify your suggestion, if I apply 12 volts via a battery of correct polarity to the diagnostic plug black - and red + wires I should hear the fuel pump run for a few seconds, does it do this short run until it reaches the 50 psig and then shut off.  Guess a battery charger is too dirty of a DC output.
    I sent you a PM, give me a call.
  8. 27 minutes ago, oaktrials said:
    If I put some gas on a rag and insert in air intake it will start and run and idle perfectly.
    So it's not a spark problem.  That leaves fuel.
    Everybody that owns an EFI OSSA really needs to have K-Scan!
    If you wire the connector described in this document:
    you can supply +12V via an external battery.  You should hear the fuel pump run for a few seconds each time you connect the battery.  Start there -- no computer or software needed.
  9. You know, car racers laugh at motorcycle racers saying we can't even change the overall gear ratio without changing the wheelbase too.  Unfortunately, I have to agree with them.
    If the wheelbase changes as a result of the gearing change, this can have a cascading effect on other tuning variables.  Moving the rear wheel rearward lengthens the lever arm acting on the shock.  This in turn makes the shock spring feel softer to the rider.  Without a change in preload, a softer rear spring increases rear sag which changes the bike's fore/aft weight distribution (and therefore traction).  These are subtle, but noticeable, changes and often a rider will subconsciously compensate with a change in body position.
    Speaking from personal experience, my OSSA TR250i "works better" in 3rd gear with a 9T front sprocket than in 2nd with the standard 11T.  The overall gearing difference is an almost insignificant 1 percent.
    And, yes, a 9T front sprocket is horrible from a chain-life standpoint -- but only slightly more horrible than a 10T or 11T.   Industrial designers generally consider 17T as the smallest sprocket that should ever be used.
  10. Oaktrials, thanks for sharing your success story.  Your description reinforces how I think the AAA cell in the Easy Start gets recharged.  Originally, I thought it stole power from the stator's fuel pump winding (which provides the Flywheel Armed Condition).  Later, I came to believe the AAA cell is recharged via the red and black wires because this is the only way an Easy Start could work when retrofitted to an older-model bike.
    I would bet your old AAA cell would still work now that you've fixed the wiring.
  11. Have you ever parted-out a complete motorcycle? I have not, but have sold various parts of motorcycles.  The lower the price, the quicker they sell (if there's a market for them).  You will probably have to ship internationally.  My guess is that it could take years to sell 50% of an EFI OSSA.  There are some parts that may never sell.
  12. Breagh makes a perfectly reasonable argument.  Selling the bike as a project would be infinitely easier than parting it out.  But even selling it as a project may not be easy.  The US market is small and it's unlikely you'll find a local buyer.
    Alternatively...  graphics is a "don't care" issue for me.  Make the bike functional and forego the appearance.  I have a huge amount of time and effort in my EFI OSSAs.  They return that investment by working exactly to my liking. (I just bought a 4RT for practice and will save the OSSAs for competition.)  In the end, I love tinkering with bikes and if I have to make/repair or modify parts to keep the OSSAs running, I'll do exactly that.
    If the OSSA performs to your liking, fix it.  If not, move on to something else.
    • Thanks 1
  13. I just tested the compression on my 2016 4RT 260 (which runs flawlessly).  I saw just over 200 psi on a cold engine after 16 kicks with a high-quality Snap-On gauge.  I observed no increase in pressure after 20 kicks.  These were not "fast" kicks, just normal kick-starting speed.  Local atmospheric pressure will have a small effect on the reading, but I would say the decompressor (if it even exists) does not work as Montesa describes!
    P.S. I'll also add that although I appreciate the quality of the Montesa service manual, it appears Honda just "cut and pasted" some of the information directly from their motocross manuals. Rings every 6 months?  Piston every year?
  14. 1 hour ago, ivanrs01 said:
    ...the problem of high compression can also be due to excess carbon in the combustion chamber according to the manual.
    True, but that will increase the pressure by a relatively small amount -- not from 65 to 200 psi.
    Did you try jimmyl's suggestion about setting tickover/idle speed?  You need an accurate tachometer to accomplish this.  I tried to set it with my digital timing light, but the reading was erratic.  Ironically, this simple device measures rpm quite consistently: https://www.trailtech.net/tto
    P.S. I'm curious, what do other 4RT owners use to set their idle speed?
  15. While testing compression are you kicking so rapidly that the decompressor behaves as though the engine is running?  That would explain the the high pressure reading.
    I'm just guessing here, but typical kick-starting speed may be 250 rpm. The decompressor probably deactivates at around 1000 rpm.
