30 -
Are all wheel bearing the same in a rear wheel from a KTM (125-525cc) I've bought a wheel off flee bay and the bearing need doing but I'm unsure of the age and cc the wheel came from. Regards
Rad cover is held on with cable ties seems a little 'heath robinson' to me, just like the CDI cover, not much thought has been put into the product from a practical point of view, and are they really needed, or are they just there for us to spend extra money on. Sorry to hijack your thread
only if you know where they are, and people will not give that info up easily
I also know the guys from BVM, the two young lads in the parts dept are very good riders so the 08 bike your on about would have seen a lot of full throttle action perhapse this is the reason for the rebuild, also remember if the engine had seen a lot of action then the other components would have as well and not been replaced (forks, rear shock etc). Have a look at the coating on the forks if this is starting to wear then i would be walking away rather quickly
I've got a Beta Rev3 06, and have replaced the rubber shock protector a few times in it's life do Gasgas and sherco's use the same type of rubber guard? I pay about
Thanks for the reply, Okay, i think i know where i'm going wrong, i will try it tomorrow
Can someone please help me here before i go out of my mind.......I've taken the clutch plates out, cleaned them and roughed the surface and have replaced them, checked the springs and cups and replaced them aswell, can someone please tell me the steps to setting the clutch, i've had a go and got no-where. Many Thanks
Okay.....I bought a new mid box from Sammy Millers and it did the job.....A new MOT was to follow Yippee
Okay just got back from the MOT station today, and it failed on 'noise' only, now that's not bad for a 1973, people that know about Bultaco's know they have a 3 piece system, well.... i have the last section missing so i expected it to be loud, is there anything that i can do to quieten the old girl down without having to buy the final section, can i pack the second section with anything just to get it through the MOT?
I find black round ones very good, for both the front and the back. Come on Scott make your decision........and let's go and have some fun
I've cleaned out the carb, there was fine dirt at the mouth of the carb, this must have got through the air filter, I'll see what happens. How do you know if the engine is getting hot, the fan cuts in and out but can you adjust the temp sender to come in at a lower temp?
when did you last change the gear oil? it's time to change the oil if your having problems changing gear
It's been doing it for about a month now, i'll clean the carb and jets and see what happends. It ran great before
Hi chaps my 270 (06) has started 'hunting' (not a steady tick over) after about 1/2 hours riding, Ive not changed fuel or mix %, air filter is clean, can anyone help. Many Thanks
