I had one, it was little used when I bought it i had it for about 2 years with no major faults at all. I thought it was an exellent beginners bike with good suspension, smooth power and a really good hillclimb bike.
My friend has it now and it still performs reliably despite a severe lack of maintenance!!!!!!!!!!!!!!!!!
My 04 300 has the std ally center box wheras my mates has the steel box (its "I didnt do the Scott" Jenkinism's old bike), and my bike is much easier to ride for a less than average rider.
Right here goes from memory!!! Once you have unscrewed the big nut on the top of the fork leg you can slide down the inner fork leg you can then see a piece of plastic tube and below this the spring.
Now you will need to make a large washer woth a 10 mm slot in it, you can then pull down the plastic tube and spring and slide the slotted washer in below the locknut on the cartridge spindle.
The big nut on the top of the fork leg can then be removed, push down on the spring again pul out the washer and the spring can be removed.
Hope this makes sense but pictures would be better!!!
Try and go as recent as posible, avoid the old scorpas they are heavy and outdated, A Techno would be OK, best bet would be 2000 gasgas 250 good suspension and exellent power delivery!!
Sammy miller used to do a 150cc conversion for the tl125 in the 70,s I can remember riding one both before and after the conversion it made a noticable difference.
They may be still available I'm sure someone will know!!!
I took my V55/4 and a cert of newness and the cert of conformity from Gasgas UK to my local licencing office (not me in person though) the first time I was given a single vehicle approval form to fill in!!! (these are for kit cars).
The next time they thought it was too old as the date on the cert of newness was for august and they want to inspect the bike!!!!
Any thoughts???
Can you just post the documents to them to save wasted journeys?
My 2000 model was one of the best bikes Ive had, Ideal for a beginner or a clubman . exellent suspension, nice smooth power, 6 usable gears and good reliability in fact good enough to sell to a friend who is still using the bike now!
It pays to find one in top condition, mine was as new when I bought it and I kept it well maintained (Its new owner just seems to ride and wash it though!!)
Ive just swapped my 02 scorpa for an 04 300pro (June this year), I find the Pro a much better all round bike to ride being lighter, more responsive, a much better clutch and riding position.
As for reliability ive had no problems with either bike but I do spend time in the workshop. The pro air box uses a different method to other bikes, it is the Motocross type with the filter covering the air intake pipe to the carb so if the air box does get abit dirty or wet it wont reach the engine. Any water can drain out of the bottom!
Ive had no over heating on my 300 so the 250 should be OK.
Scorpa 250 4t
in Scorpa
Whats all the fuss about these heavy 4 stroke lumps?? They are just the emperors new clothes!
A couple of years ago would anyone consider buying a bike 5Kgs heavier than the best of the rest?(nearly a stone!!!!!!!!!!!).
