I think they started out the same length and then the top bit was broken, probably when fitting ne seals. I've seen a couple of places repairing these. You might find it cheaper though to pick up a s/h assembly, these forks were fitted to many bikes including fantic SWM and Armstrong so they do turn up fairly regular
I've noticed a few less postings, but more worryingly the news and results sections seem to be way out of date. Also I post our clubs newest results, but it seems to be ages before they appear yet the ones from our trial in November are in the latest results column
I dislocated my shoulder last year, I now have a pair after being high sided off my enduro bike 25 years ago. This one is causing me more problems though and I want to do something about it. My area NHS does not operate on this condition so I've been looking at going private. Had anybody any experience or recommendations? I asked both the ACU and the AMCA but neither had the courtesy to reply!!
I've found some bits are good, engines and ignitions whilst others are poor, for instance engine bolts made out of putty and frame welds done in the dark
Check the obvious first. Look for dodgy wiring, take flywheel cover off and make sure that it has remained dry. Flywheel off and clean up check on woodruff key. Try for spark direct, take plug cap off and hold near to barrel.
I disagree, i've had 2 and both were good. Very strong motors and reasonable handling make for a good novice and up bike. New spares are difficult but there is a specialist breaking them for spares. As with any water cooled bike if you boil it and keep running the damage will be terminal
Often the delorto has 2 slow running jets in the same hole, I know I missed that a few years ago. Worth considering taking it to Bill Pye who is not a million miles away. Need to get a move on though there is less thn 3 weeks to go to the Midland Classic trial at Rhodesia which is vey close to you
What I have found with little bikes is that the slow running jets and galley ways are so small that they easily get blocked and are very difficult to clear out.
I've glued Suzuki magnets back in using Araldite (not the quick setting stuff). You should be able to see where the magnets were positioned, just takes a close look and a bit of detective work.
If you go too low on the primary, clutch slip could be a problem. It also makes the bike harder to start. I prefer to go as low as possible on the gearbox sprcket
Montesa315r '98 forks
in Montesa
Use a strap to put the forks under tension and try again
