Filter
jonny beta
Yep always oil it. Even applies in dry weather where the Dust can cause you problems if it gets into the cylinder. As for patience I had problems getting the filter in the first couple of times but seem to "have the knack" now!
some people do it easier with their left hand others like me who take the airbox off a fair bit do it then. My best solution is to carefully remove the wing nut from the thread, cut through weld, and replace with a knob.
Oil in dry conditions is more important than wet. I Always oil and use the proper stuff it is sticky for a reason.
There's an echo :D
