September 22, 200719 yr I am new to trials riding and i have been looking for a trials helmet! what sort of makes would you recomend and my price range is around Edited September 22, 200719 yr by TY250Henry
September 22, 200719 yr Try on all helmets and buy the one that fits you the best. Make sure when your head is bent slightly down you can see under the peak Personally i need a helmet with a removeable washable liner and i like the seat belt type fasteners other than that make sure its a good fit a large in say a Hebo may be equivelent to a medium Shoei.
September 22, 200719 yr I've used both & would say that the Airoh is a considerably better piece of kit, when I replace mine it'll be with another Airoh.
September 22, 200719 yr i like my hebo it's comfy and good value but prefer my dads airoh its more expensive but lighter.hope this helps
September 23, 200718 yr The shape and size of everyones heads are different. You must try on the one you want to buy.Most have removable liners now which is essntial. I have always gone for Shoeei as they fit me so well, but tried on the carbon Hebo and that was alot lighter, but fitted as good.
September 23, 200718 yr I agree with Nigel, go for a helmet that fits your head well, has a removable liner, has air vents, preferably a stainless steel buckle and strap rivets (hard to find but Shoei used to do one at a price), and is light weight. Usually a carbon fibre one from Hebo weighs approx 950 grams, polycarbonate helmets are approx 1150 grams. Bye, PeterB.
September 23, 200718 yr Author Thanks guys for all the help i have had a look at them and like them all but will have to buy the one i like the best i cant spend to much now because i have goon for a bike that is more expencive than i planned. But still want to get a high qaulity one because its esential when riding a motorbike. Many Thanks Henry Edited September 23, 200718 yr by TY250Henry
September 23, 200718 yr With a helmet, you never want to compromise quality, for price. I have come across the Shiro brand (made in Spain) and find it to be a great balance between price and quality. Don't know the distributor, or price in the UK, but you can pick one of in the US for $162.
September 23, 200718 yr This is probably a silly question but do helmets have a 'use by date'? I bought a carbon Hebo, which is a great helmet but its probably 5 years old and has had at least two pretty hefty knocks to it...
September 23, 200718 yr This is probably a silly question but do helmets have a 'use by date'?I bought a carbon Hebo, which is a great helmet but its probably 5 years old and has had at least two pretty hefty knocks to it... Yikes! Toss that helmet now! Helmets are actually single-use items. If they've taken a hard hit, they are done. You can't see the damage that has been done, but that doesn't mean it's not there and you're riding around with a false sense of security. And, yes, the styrofoam gets old and loses its protective value. Here's a site on helmets with good info. It's for bicycles, but the information translates directly to us: http://www.helmets.org/replace.htm Here's some good info from Snell: http://www.smf.org/faqs.html And from HJC: http://www.hjchelmets.com/helmet_usage.htm Everyone agrees...your helmet is toast. Replace it before your next ride.
September 23, 200718 yr With a helmet, you never want to compromise quality, for price. I have come across the Shiro brand (made in Spain) and find it to be a great balance between price and quality. Don't know the distributor, or price in the UK, but you can pick one of in the US for $162. I'm interested in one of these but I don't have the luxury of trying one of the Shiros on for size since noone close carries them. Do they run large/small? What is your hat size (or head circumference) compared to the Shiro helmet size that you ended up with (s/m/l etc.)? Thanks, J.
