November 17, 200719 yr hey all, on a mikuni carb which way do you turn the mixture screw to make it leaner? thanks Jack H
November 17, 200719 yr I disagree, I believe that for making it leaner you need to turn it out (i.e. anti-clockwise).
November 17, 200719 yr Which side of the carb is the screw on? Nearer to the airbox or the engine? If airbox, unscrewing = more air (leaner) If engine, unscrewing = more petrol (richer) *DISCLAIMER* The above might be utter b*****ks, as I can't remember either
November 17, 200719 yr Well as an ex M/C mechanic it was always out for leaner and in for richer(shutting off the air) never the other way round. 3 x City and guilds in the subject. But as I tell folk I have forgot more than I ever knew.
November 18, 200719 yr Out is leaner on the Mikuni VM carbs. The mixture screw on the mikuni is in the air circuit. Out is richer on the Del Orto because the mixture screw on the Del Orto is in the fuel circuit. Dan
November 18, 200719 yr Which side of the carb is the screw on? Nearer to the airbox or the engine?If airbox, unscrewing = more air (leaner) If engine, unscrewing = more petrol (richer) *DISCLAIMER* The above might be utter b*****ks, as I can't remember either In my experience Mr Kinell is right. You can check by going to both extremes, you should be able to tell if its too rich or weak
November 18, 200719 yr Hi Jack_H, Kinell is correct! If the mixture screw is between the carburetor slide and the airbox, the screw controls the amount of air and should be turned outwards, anti-clockwise to lean the mixture. If the mixture screw is between the carburetor slide and the engine, the screw controls the amount or fuel and should be turned inwards, clockwise to lean the mixture.
November 18, 200719 yr Link below for Mikuni manual. The graph on page 10 shows that as the mixture screw (air screw) opens,the flow of fuel decreases, therefore the mixture becomes weaker....alegedly! http://www.mikuni.com/pdf/vmmanual.pdf
November 19, 200718 yr I'm beginning to understand why you guys have so many problems getting your bikes to run right with the Mikuni. Dan
November 19, 200718 yr Link below for Mikuni manual. The graph on page 10 shows that as the mixture screw (air screw) opens,the flow of fuel decreases, therefore the mixture becomes weaker....alegedly! http://www.mikuni.com/pdf/vmmanual.pdf ....oops! Meant to say the flow of air increases!
