scorpa4banger Posted July 27, 2008 Share Posted July 27, 2008 Has anyone got an Amal Mk2 for a 158 75/76 sherpa T 250 lying around ? ( long shot ) or know of anyone thats converted to a Bing or Mikuni and know what jet sizes needle pos etc and what type of carb was used ? or cheers Quote Link to comment Share on other sites More sharing options...
swooshdave Posted July 27, 2008 Share Posted July 27, 2008 Might help if you updated your profile with your location. Makes it easy to determine if it's going to be easier to ship something to you or to point you to a proper vendor. Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted July 27, 2008 Author Share Posted July 27, 2008 Perth Western Australia Quote Link to comment Share on other sites More sharing options...
peterb Posted July 28, 2008 Share Posted July 28, 2008 Aah, the West Island (NZ joke). If you can't get a good Mk 2 concentric, then you can consider a DellOrto PHBH 26, as fitted to most of the GG bikes. Std set up is fine except you need to have a 95 main jet, or if you can't get one, solder up the original (118 usually) and drill 1.00 mm, that's close enough. Works perfect. Have fitted these to many Bultaco's, 325 & 250 also Ossa 250. Never had any joy at all with the Mk 2 concentrics (used) they were just plain awful. If you are stuck I have everything here in the mainland! Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted July 28, 2008 Share Posted July 28, 2008 PeterB Where do you recommend getting one of those DellOrtos from? Thanks David (also from the West Island of NZ) Quote Link to comment Share on other sites More sharing options...
scorpa4banger Posted July 28, 2008 Author Share Posted July 28, 2008 Hi mate cheers for your help couple of questions 1stly where can I get one ? what sort of throttle cable would I need ? the throttle is chrome and spilts into two halves not sure if thats standard or not ? also would I need any differant size rubbers on the inlet and outlet ? so all you need to do is order a standard carby but with the differant jet ? is the pilot and needle etc still okay ? thanks Quote Link to comment Share on other sites More sharing options...
dabdab Posted July 30, 2008 Share Posted July 30, 2008 As the Cuz Bro ( Oz joke ) says, the Dellorto will do. As to throttle, and cable, use the standard Sherco SLOW ACTION twist grip and throttle cable-plenty of spares, save soldering bloody cables Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted August 12, 2008 Share Posted August 12, 2008 why bother with a Dellorto? Get yourself a flatslide! Quote Link to comment Share on other sites More sharing options...
branc Posted August 18, 2008 Share Posted August 18, 2008 On a 350 sherpa what would be the best carb setup? What jetting would you use with a dellorto? Thanks in advance Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted August 18, 2008 Share Posted August 18, 2008 For a 350cc get yourself an OKO 28 or 30. They are not expensive and come pre-jetted for your bike..this is where I got mine...best money I spent in yrs www.oko-australia.com.au Quote Link to comment Share on other sites More sharing options...
peterb Posted August 20, 2008 Share Posted August 20, 2008 Hi branc, You can consider a DellOrto PHBH 26, as fitted to most of the GG bikes. Std set up is fine except you need to have a 95 main jet, or if you can't get one, solder up the original (118 usually) and drill 1.00 mm, that's close enough. Works perfect. 60 slide, D36 needle, 270K needle jet, 33 pilot, pilot screw out approx 3.5 turns. I have also tried a Keihin flat slide PWK 28 with std jetting for a Gasser, but with 100 main jet, works the best out of DellOrto, Mikuni and Amal but then when I fitted this I also fitted a PRO reed valve block and did a little porting work so it was not a fair test. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
