Montesa Cota 242
sooty
Tbh on mine once the points was set up correctly i never had a problem with them, the engine is just weak on low end throttle range, if this electronic ignition can race the engine up like the fantic engine does i can see the 242 becoming abit more popular.
Until the points wear.
I meant with this new setup, once set, its set for life, as it has no touching parts to wear out, only a failure of a component would require anything being changed.
  • 5 months later...
Update on the CDI install:
bike has been running great, only one fault, pickup failed, called Julian and was sent a replacement without any problems, fitted and no issues since..
Also have fitted a new Mikuni card from in motion, running even better now.....
  • 2 months later...
Please sign in to comment
Sign In Now
