03 Sy 250 Oils And Things
Masso, this is the sump plug paulmac and Godzilla are talking about in this thread. It is made out of soft material. It
  • Replies 46
  • Views 19k
That is one nasty looking sump plug, Mine was tight, started to round off, I hammered a socket on and managed to remove the plug. squeezed together chocolate wrapper has more structural integrity than the material that sump plug is made of. Replaced it with a Hell team one - good kit. took about a week to arrive from Australia.
yikes!....and yours is an 06!!..you'd think a newer bike wood come off easier....what exactly is this plug ???
Yo Masso
I've sent you an email - that is THE drain plug
Paul MAc
yikes!....is this some kinda jap revenge ...stupid material for such a part!....how did you ever figure out the ninja 250 thingy?
you could forget it and just use the drain plug under the shifter ....its easier
Masso, I had a 250 Ninja parts engine lying in the garage, so I checked.
Unfortunately you have to remove the sump plug. The drain plug under the shifter is not enough. I removed it, and laid the bike on its side for maybe 24 hours. Only got a little oil out…
Btw, where is salt-spring island?
Edited by G520
dude...saltspring is in trials heaven!.....west coast of canada near vancouver....lots of sinle track forest riding ....masso
Interesting, thanks. I took a look in google earth. Seems like a really beautiful place. Maybe I will take a look sometimes, when I visit my sister in Vancouver..
Sorry to wander offtopic, I will keep focused from now on.. :)
now, you gotta admit...google earth is some kinda wonderful!.........hey, I think I'll go over to paris today, have a look around, no. I'll go to mems and check out the scorpa factory!
  • 3 weeks later...
Hi all. I have just finally got round to changing the gear oil and hey presto.......rounded the plug off !
Armed with the info supplied on here I set about removing the sump guard, and found myself a good six point socket (12mm I think). I reached around the bike (yes I gave it a reach around) so as to pull the ratchet and socket upto the bolt head. One slight careful bit of a turn later and I'm shaking my head in disbelief... :biggrinsanta:
The bolt head had nowhere to bend in my six point socket, there is no way it could round off. How wrong was I.
Anyway, better luck tomorrow I hope.
Does anybody know what thread the plug is cos I might just drill it out. and re-tap.
WHAT ABOUT VISE GRIPS?
well, you can still drain your oil using the drain bolt on side under the shifter[one with copper washer]
Hi
had the same on my 05 250. I hammered a slightly smaller socket on,and used an impact driver - it came off no problem. I then replaced with an aftermarket from birketts and had no further problems !
Cheers
John
Same problem on my 05 first time I needed it out.
Used a chisel punch to turn it out and bought a standard inexpensive bolt/screw from local fastener company,
cut to length and been fine ever since.
Please don
Why has nobody suggested taking the clutch cover off ?
It would only take a minute and easy to do, or is there another problem that I don't yet know about ?
I tried the chisel, then the vise-grips and no joy.......I usually like a challenge but could do without this one. Its 1-0 to the sump plug. :biggrinsanta:
