ma77 Posted November 14, 2009 Share Posted November 14, 2009 Im rebuilding/restoring a montesa 200 and can not find parts any where... where are the best places to go for parts? after a quick glance at what i have i will be needing a engine gasket set and possibly a few small engine parts other than that it will need all the usual service items (bearings, brakes, cables, levers, ect) thanks for all the help Quote Link to comment Share on other sites More sharing options...
motovintage Posted November 14, 2009 Share Posted November 14, 2009 Not sure where you are, but in the US try southwest montesa or lewisport, if in the UK try sandifords Quote Link to comment Share on other sites More sharing options...
ikb Posted November 15, 2009 Share Posted November 15, 2009 Inmotion Trials have gaskets and stuff so does SammyMiller Products and theres a fair bit of stuff on Ebaay (uk site). Quote Link to comment Share on other sites More sharing options...
ma77 Posted November 16, 2009 Author Share Posted November 16, 2009 thanks for your help. im in the uk just down the road from sammy millers, in fact we rent or workshop space from him. i will have a look at what you sugessted Quote Link to comment Share on other sites More sharing options...
midlife Posted November 23, 2009 Share Posted November 23, 2009 Hello try this phone number he helped me out? 07773927820. Quote Link to comment Share on other sites More sharing options...
ma77 Posted November 23, 2009 Author Share Posted November 23, 2009 i have sourced a base gasket Quote Link to comment Share on other sites More sharing options...
sensi Posted November 27, 2009 Share Posted November 27, 2009 Hi I currently own a 1981 Montesa Cota 200 & have an original sales manual. The engine exploded view does not show any head gasket present. I have never had the head off mine so none the wiser.However, it does show either a very thick base gasket or base spacer that i would be interested in determine thickness. Parts for this bike are difficult to find, the sources already mentioned other than Sandifords are the only sources that i have found. I could photocopy manual if you like & will try to Email a phone number or something. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted November 27, 2009 Share Posted November 27, 2009 Yes it is standard practice on some bikes to have the head sealing against the sleeve without a gasket. The sleeve usually sits proud of the top of the barrell on such bikes and there is usually a recess in the head that locates on the sleeve. The head being aluminium and the sleeve being cast iron or steel makes for an effective joint. Quote Link to comment Share on other sites More sharing options...
johnh Posted November 27, 2009 Share Posted November 27, 2009 The 123 head has no gasket either. I have got most of the parts I needed from InMotion, BVM and Sandifords. Base gasket was listed aas NLA so I bought some gasket card and made my own, seems OK but the test will be when I fire it up again. The gearbox cover gasket might be a home made job too! Quote Link to comment Share on other sites More sharing options...
ma77 Posted November 28, 2009 Author Share Posted November 28, 2009 well i am rebuilding the engine at the moment and so far the only bits missing are a few washers, circlips and springs which i have found new ones i will have to order some new oil seals and have had to weld a small amount on the gear shift shaft spring rest. i will probably make a base and cover gaskets and use some sealer on the head so it shoud be rebuilt by monday if all goes ok thanks for all your help and to sensi for all the info he gave me over the phone.... was a lot of help Quote Link to comment Share on other sites More sharing options...
ikb Posted November 28, 2009 Share Posted November 28, 2009 I got my seals from simplybearings.co.uk, cost just over a quid each and cheap postage although I got viton ones for the crank and they were a bit more!! Quote Link to comment Share on other sites More sharing options...
ma77 Posted November 28, 2009 Author Share Posted November 28, 2009 yes i have used simpleybearings many times and although they are a little more pricey they do have the best search design and i have always found the bearing i need. engine build has been held up a little as the clutch cover has a crack in it and our tig welder is not rigged up yet Quote Link to comment Share on other sites More sharing options...
