Sherco Not Starting
hi my sherco 250 wont start i have been trying for about 3 hours and no joy
when i kick the bike the light is coming on and ths it, it hasnt been started for abut 2 an a half months
i can put it down to the cold weaher and that i just want to get it started if anyone can help that would help
that wuld begrat thanks
Edited by sherco25016
You have to show the bike who`s the boss. Make sure the petrol to the on position. After ten kicks, throw it to the ground in disgust. Jump up and down on it, yelling `piece of sh?t, piece of sh?t!!` Then pick it up and it will start with in two kicks. Works 99% of the time.
Are you lost?? This is Beta land........OOOOH it's dark in here !!
Did'nt spot that :biggrinsanta: Drain tank and carb, clean carb, new fuel and plug away she goes
Take out the engine and put a Beta one in. Then replace the frame, plastics and electrics with Beta ones - job done! :biggrinsanta:
change it to a beta ha betas are only good for bonfires
First post is the way I like to show the newbies. If your bike has sat for a while the easy way to get it started is to lay it on it`s side till you have fuel coming out the the over flow. This should prime the engine and start first or second kick. I this does not work you might need to clean the carb, pilot jet is probably plugged up.
I like to throw in some language for the spectators.
Tell you what, send it to me and I'll get er runnin' for you :rolleyes:
I'd try the new plug, fresh gas, drain the float bowl, turn the gas on, and it'll come back to life. If not one of the jets are probably gunked up.
Edited by flynz4me
