March 27, 201016 yr Hi all, Need some advice on what psi i should have in my back tyre?? Im 15 and half stone and ride a sherco 290, not doing massive jumps yet but going over 3ft walls, Any help would be cracking Jay
March 27, 201016 yr dry conditions I have been know to run 5 rear and 7 front. I am 16.5 stone. (230 lbs) Most often 4 rear and 6 front. Good size steps and such.
March 27, 201016 yr Brand of tyre also has an effect, if you make the mistake of buying a vee rubber you'll need to be closer to 2psi. Have heard pirelli's are no better
March 27, 201016 yr Brand of tyre also has an effect, if you make the mistake of buying a vee rubber you'll need to be closer to 2psi. Have heard pirelli's are no better If it's Pirelli's just let all the air out and run em flat, they still won't grip worth a **** but they'll still look fully inflated Edited March 27, 201016 yr by Slapshot 3
